Question about Yamaha RX-V1600 Receiver
Yamaha rxv1600 after 16 mnths of using this amp it refuses to turn on , i have checked everything no wires were tourcing each other . only the clipping sound at this stage ? whats wrong with it?
Have you any further info on this fault. I have the same fault now.
Posted on Nov 22, 2009
My 1989 yamaha waverunner wr500f has been running fine. I rode it yesterday and it was fine. Took it in the water today and it wont do anything.. not even turn over. I tried a new battery, checked all...
Such vehicles are often fitted with a "dead-man" type safety device that cuts the motor if the rider is thrown off or perhaps another type of emergency kill-switch. It is also possible it is fitted with an anti-theft device...
It is those sort of devices that are often overlooked when a motor refuses to start and resists all the usual fixes. Safety and security devices do cause problems sometimes.
Often only by referring to a circuit diagram and using a voltmeter or testlamp can the fault be found.
Feb 04, 2018 | Sport & Outdoor - Others
Does not switch on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
Jan 18, 2013 | Yamaha RX-595 Receiver
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
On my HTR-3063, I could not get it to come on. So, I unplugged all the cables and speaker wires, and I plugged it in without any plugs or wires, and it turned on. So I changed all my wires and HDMI cables,...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Add things one at a time until you identify the one component (probably a speaker) that is causing the problem.
Mar 22, 2011 | Yamaha HTR-3063
I JUST REPLACED MY OLD RECEIVER WITH A YAMAHA AND DON'T SEE WHERE TO CONNECT THE POWER FOR THE CD AND TAPE PLAYER. DO I PLUG THEM INTO A POWER STRIP?
Yes, that will be fine just make sure its the same AC power as the new Yamaha is using.
Before connecting any AC mains always turn off your Amp, and don't turn back on again until all the signal cables for the new equipment are connected.
When checking if it all works, always start with low volume to check everything is correct.
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | Yamaha RX-V663 Receiver
IF YOU WHERE TO PURCHASE A USED 2005 MAGNUM WITH 80,000 ON IT WOULD YOU PURCHASE THE WARRINTY PACKAGE THEY OFFER?
No the warranty they offer, Unless its a factory warranty you can go online and buy cheaper from the same company, The car dealer wont have his fingers in the pie getting a kick back
Jun 10, 2010 | 2005 Dodge Magnum
My 2004 Yamaha Royal Start Venture will not start. Battery is good. nothing turns on in any key position. Just got back from a ride and was going to go on a quick one. Got on the bike, turned key, bike...
1st check the fuse(s) including the main fuse on the starter solenoid.
Then check battery connections are tight.
If OK then check wiring & connections from battery to starter solenoid to ignition switch, but with no meter it will have to be a visual check for bad connections or squashed wires
Hope this helps (if so please mark as very helpful)
Ride Safe
Bike-Doc
Apr 15, 2010 | 2004 Yamaha Royal Star Venture
Buzzing on certain speakers (but not all)
do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Feb 01, 2009 | Yamaha HTR-5840 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
Yamaha RX-V1600 Receiver Logo
423 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
