Question about PfaFF Creative 7570
Pfaff 7560 won't take Enter key
I have always enjoyed my machine and embroidery unit but after not using it for a year; it does not work??? it stated: change the batteries which I did but still get the same message I asked an owner of a Pfaff dealership today and she said there was a glitch in this message and when that happened I had to press two buttons together BUT she couldn't remember the numbers. She said she would try to find her old notes on it. She was extremely nice but didn't solve the problem. Here's what happens: I insert disc7560 which I always use for letters; pick a memory spot etc. etc. but when I press in a letter and then enter; the enter button doesn't work and therefore when I go to save it into the memory spot; nothing shows up. I have used this machine for years and it ahs worked perfectly (the batteries had not leaked or anything like this. Hope you can help. Thanks M. Burr.
  • Manibhai Sep 05, 2017
    Back side of this enter button there is small push button,replace this button from display board
    New Friend:
    Problem Solver:
  • 17 Answers
First, make sure your batteries are new, and not cheap ones. Change them again if you are in doubt. Try pressing ANY two buttons as an experiment. If this fails I can't help, but try another dealer, preferably ask to speak to their repair man. Good luck !
Posted on May 04, 2017
    And change bettery when machine is on
5 Suggested Answers
  • 8 Answers
SOURCE: Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Posted on May 20, 2008
  • 8 Answers
SOURCE: PLEASE HELP!!! Pfaff creative 7570 tension problems
Check your bobbin tension also. Embroidery bobbin thread is finer than sewing thread and you may need to make adjustment on the bobbing case by turning the small screw slightly. The type of stabilizer can affect your embroidery. An excellent reference for machine embroidery is Embroidery Machine Essentials by Jeanine Twigg, available on Amazon.
SewTechWayne
  • 186 Answers
SOURCE: start up on pfaff 7560
A lot of people don't know this, but there is a dimmer dial on the front of your machine, located just under the display. Often it gets bumped and the display disappears. If not then you need a fuse in the base plate or worst case a new circuit board.
Posted on Jan 30, 2009
SOURCE: Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Posted on Aug 14, 2011
Machine left unused for a long time; (pedal & almost everything missing except the machine itself ;) The problem is : when the machine is plugged , the screen won't light up, it simply won't turn on
My Pfaff 7560 had done the same thing. It was determined that the mother board needed replacing. For either machine the part alone is around 600 bucks provided that one can be found. Labor wasn't factored in. I decided that if I was to invest that much money in repairs that I would buy a certified used machine that uses current technology. The 7560/7570's software doesn't work under Windows 7 or 8.
Apr 01, 2015 | PfaFF Creative 7570
What format does the Pfaff 7570 use for embroidery?
The format that is used by the 7570 and the 7560 is *.pcs or *.dst. Either one will work provided that the designs are within the confines of the hoop. The largest size design that would be embroidered by this machine would be 115 x 120 MM.
Jan 03, 2013 | PfaFF Creative 7570
Pfaff 7560 transfer cable
CLICK HERE for the software and the connecting cable. A bit more expensive than my earlier posting.
Jun 12, 2012 | Sewing Machines
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
sewingpartsonline.com
May 02, 2012 | PfaFF Creative 7570
Need a user manual for a pfaff 7570 sewing machine
contact pfaff customer service or sewingpartsonline.com
Mar 19, 2012 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Pfaff 7570 program
I have somewhere that installation diskette (with the old SW version). If I'm not mistaken it was not included with the sewing machine but sold separately with the embrodery arm that we bought together with it some 10 years ago. Email me to azach@kci-medical.com if you need more help.
Jan 08, 2009 | PfaFF Creative 7570
Apr 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
150 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
