I get buzzing sound in my speakers when I switch to the phono stage on
my receiver. I noticed that it is related to the dimmer switch
controlling the track lighting in my living room. When I turn off the
lights buzzing sound disappears. Right now I plugged my turntable into
the contact furthest away from the dimmer, it helps but the buzzing
sound is still there. Is there a piece of equipment that will eliminate
the problem.
Please advise. Thank you.
It is a grounding issue with the turntable most likely. Some turntables came with a ground wire that you attached to the receiver. You can also try a power strip that has a line filter incorporated to get rid of the hum. Check the local stereo shoppe to see if they carry them.
You may also want to replace the audio cable that connects the turntable to the amp with a good quality shielded cable. If it has bad shielding it will pick up electrical interference and even radio interference as well.
Turntable inputs on receivers have a preamp built in and the gain for each type of pickup is different. The pickup is either ceramic or magnetic and if I remember correctly, the ceramic pickup needed more gain than the magnetic one. The preamp will definitely make a ground hum a lot more audible.
Cheers and good luck.
thank you very much I will try it.
