FixYa.com
Tags:
V, Inc. V, Inc. VIZIO RP56 Rear Projection Television
Since yesterday i have a BLANK SCREEN on my Tv, can... (by 8 users)
By Luisa_K - usenet poster
since yesterday i have a BLANK SCREEN on my Tv, can u help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by randyf, posted on Jul 20, 2008
my Mitsubishi VS-50801 50 in. Rear Projection Television has no picture but does have sound
Comment by Guest, posted on Jan 21, 2008
I heard a PoP sound and now there is no Power to the TV??????, it is plugged in to a live outlite.
Comment by bobby boy, posted on Jan 03, 2008
My 37' Vizio keeps going blank? It will stay on for 10 minutes or so and then the picture goes blank...there is still audio and it responds to changing the channel just no picture? I reset the options like they told me and that seemed to work, for about and hour. What do I do? This is a new tv and their tech support takes forever to come out and help. Should I just take this thing off the wall and return it?
Comment by krod, posted on Dec 28, 2007
i heard a pop sound,and now there is no picture,but when i try to go into the menu the lettering is in red, green,yellow. triple,but still no picture,also no sound.
Comment by Raising_Kane, posted on Dec 25, 2007
I have the same problem on my VW 37 LCD TV. Usually if you aren't sending signal to the TV a blue screen saying "no signal" should be on. I was playing my PS3 through the HDMI connection on the back of the TV and I left the room to grab my phone, came back and the TV was still on but the screen was black. I turned off the TV thinking I sat on the remote control and changed something. Now, I turn the TV on and it gets power but no picture, no sound... nothing. I've tried disconnecting everything and letting it sit... no results, their tech support is horrible. I have to take mine back to Wal-Mart.
Best Solution
posted on Aug 08, 2005
Helpful (85)
Chandler
Chandler - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
No sound or light on any channel may mean the TV is unplugged. Check you electrical connections. If the electrical connections are good, try disconnecting the cable from the television and tune to a local channel (CBC, CFTO, etc.). If you still have nothing, the TV is likely at fault.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 16, 2008
Not Rated (0)
Ecollier2012
Rank:Guru Guru
Rating: 85%, 13 votes
If you have no sound or video or if your screen keeps shrinking and expanding its typicaly the opto chip. You can get the chip and repair instructions from www.magnavoxhelp.com . This is a fairly common problem.
Solution #3
posted on May 25, 2006
Not Rated (0)
wolfg
Rank:Master Master
Rating: 74%, 9 votes
REPLACE LAMP
This Problem Also Relates To: GE 46GW947 46 in. Rear Projection Television Panasonic PT-51HX40 51 in. Rear Projection Television Panasonic PT-45LC12 45 in. Rear Projection HDTV-Ready Television Panasonic PT-50LC14 50 in. Rear Projection HDTV-Ready Television Sony KP-53HS30 53 in. Rear Projection HDTV-Ready Television Sony KP-57WS510 57 in. Rear Projection HDTV Television Sony KP-51WS520 51 in. Rear Projection HDTV-Ready Television
Can you Help with these Projection Televisions problems?
V, Inc. V, Inc. VIZIO RP56 Rear Projection...
White dot in middle of dlp...
I have a 56" Vizio DLP... Answer This...
Television
My tv will turn on but I have... Answer This...
red in back round
hello i turn on tv and it is... Answer This...
Vizio10 WV37L 10A tv controller
I just got a Vizio HD tv for... Answer This...
Vizio VW 37 LCD HDTV BIG...
I have had my Vizio for 5 days... Answer This...
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 05, 2007
You might need a new lamp. Check to see if there is a red light on the front of the TV on the lamp button.
Comment by RGNURSE4U, posted on Nov 30, 2007
I HAVE SOUND BUT NO PICTURE! I HAVE UNPLUGGED AND TURNED THE TV ON AND OFF, NOTHING SEEMS TO HELP!
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
