Question about ASUS P5BVMSE Motherboards
Serial port connector for Asus Motherboard
On an Asus motherboard I am considering, there is a 10 pin connector to which you can attach a 9 pin RS-232 port that sits in one of the slots on the back of the chassis. The so called COM module is 'purchased separately to quote the manual. Anyone know where I can actually get one from? I have done a bit of googling but so far without success -- Michael Chare Does anyone know why Windows XP doesn't seem to see the serial port bracket I finally found and installed on my Asus p5b motherboard? I only need the thing for 5 minutes to download all the addresses, etc from my old palm pilot.
  • 43 Answers
Take your pick. Here is a link
serial motherboard header to db9
Posted on Dec 21, 2008
What is a serial port and where is it on the p67 mb
a serial port is a 9 pin (DB-9) connector for serial communication (RS232) used by modems, mouse, etc... In older machines you had a DB-25 (25 pin connector) as well usually situated in the back of the computer near the printer port (DB-25 connector) but femail (25 holes insdead of 25 pins)
Hope this helps!
Aug 06, 2011 | ASUS P4P800-VM Motherboard
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
DID this HDD (Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive) can atach in ASUS K8U-X, Thank you, Nikola
ASUS K8U-X - motherboard - ATX - Socket 754 - ALi M1689
1.0 x PCI - Socket 754,
2.0 x Processor - DIMM 184-pin,
4.0 x AGP 8x,
1.0 x Memory
  • Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - RAID 0 / RAID 1 / JBOD,
    Serial ATA-150 - connector(s): 2 x 40pin IDC
  • Interfaces 1.0 x Keyboard - Floppy interface - RJ-45,
    1.0 x Hi-Speed USB - SPDIF output - 6 pin mini-DIN (PS/2 style),
    4.0 x Network - Generic - 34 pin IDC,
    1.0 x Audio - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1.0 x Audio - Ethernet 10Base-T/100Base-TX - 9 pin D-Sub (DB-9),
    1.0 x Parallel - Generic - 4 pin USB Type A,
    1.0 x Serial - RS-232 - 6 pin mini-DIN (PS/2 style),
    1.0 x Storage,
    Mouse
  • Power Connectors 20-pin main power connector,
    4-pin ATX12V connector
  • as long as the PSU and motherboards power and lead connections are the same as the hard drive
    hope this helps
    May 10, 2011 | ASUS K8U-X Motherboard
    My mothar board are pspe.vm so i know which ram add my mothar bord 512mb ya 1 gb ya 2 gb sopart my motharbord
    ASUS P5PE-VM - motherboard - micro ATX - i865G specifications
    General
    Product type (AE)
    Motherboard
    Form factor
    Micro ATX
    Width
    9.6 in
    Depth
    7.6 in
    Compatible Processors
    Pentium 4 , Celeron D , Core 2 Duo , Pentium D
    64-bit Processor Compatibility
    Yes
    Mainboard processor socket
    LGA775 Socket
    Mainboard / Multi-Core Support
    Dual-Core
    Chipset Type
    Intel 865G / Intel ICH5
    Data bus speed
    800.0 MHz
    BIOS type
    AMI
    Storage key information
    Serial ATA-150 , ATA-100
    Power connectors
    4-pin ATX12V connector , 20-pin main power connector
    Processor
    Installed Qty (Max Supported)
    0.0 ( 1.0 )
    Memory
    Cache Memory Type
    None
    Supported RAM Technology
    DDR SDRAM
    Supported RAM Integrity Check
    Non-ECC
    RAM Installed ( Max )
    0.0 MB / 2.0 GB (max)
    Supported RAM Speed
    PC2700 , DDR266/PC2100 , PC3200
    RAM Features
    Dual channel memory architecture , Unbuffered
    Video
    Graphics Controller
    Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0
    Audio
    Audio Output
    Sound card
    Signal processor
    Intel 865G
    Audio codec
    AD1988
    Sound Output Mode
    5.1 channel surround
    Telecom / Networking
    Modem
    None
    Networking
    Network adapter - Marvell Yukon 88E8001 - Fast Ethernet , - Ethernet , - Gigabit Ethernet
    Features
    BIOS Features
    SMBIOS 2.3 support , ASUS EZ Flash , WfM 2.0 support , ASUS MyLogo , Hyper-Threading Technology , DMI 2.0 support
    Manual Settings
    CPU frequency
    Sleep / Wake Up
    Wake on LAN (WOL) , Wake on ring (WOR)
    Hardware Features
    C.P.R. (CPU Parameter Recall) , Green Edition , CrashFree BIOS 2
    Expansion / Connectivity
    Expansion Slots Total (Free)
    1.0 AGP 8x - LGA775 Socket , 1.0 Memory - DIMM 184-pin , 3.0 PCI , 2.0 Processor
    Storage Interfaces
    Intel ICH5 : ATA-100 - connector(s): 2 x 40pin IDC - 2.0 device(s) , Intel ICH5 : Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 4.0 device(s)
    Interfaces
    1.0 x Audio - RS-232 - Mini-phone stereo 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - IEEE 1284 (EPP/ECP) - Mini-phone stereo 3.5 mm , 1.0 x Keyboard - Line-out (center/subwoofer)/line-in - 4 pin USB Type A , 1.0 x Audio - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - Generic - 25 pin D-Sub (DB-25) , 1.0 x Mouse - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Audio - Line-out (rear)/microphone - 4 pin MPC , 1.0 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1.0 x Storage - Floppy interface - 9 pin D-Sub (DB-9) , 1.0 x Audio - RJ-45
    Additional connectors (optional)
    4 x Hi-Speed USB
    Miscellaneous
    Compliant Standards
    RoHS , Plug and Play
    Hope this helps,
    If I have helped you resolve your problem, please
    consider giving me a good rating and a quick
    thanks or good job.It will help me as well Thank
    you.
    Oct 23, 2010 | ASUS P5PE-VM Motherboard
    How do fi find my mother board serial number
    The Serial Numbers of ASUS Motherboard will be 10 or 12 alpha numeric digits.
    The serial number will NOT start with a ZERO ("0") or contain spaces or dashes.
    Format of the serial number:
    • 1st digit: Last digit of year manufactured
    • 2nd digit: Month Manufactured (1-9, A-C)
    • 3rd digit: Product Code ("M" for Motherboard)
    Possible Locations:
    • Parallel Port
    • Side of PCI Slot
    • Side of Power Connector
    • Underneath / Backside of Product
    • Side of CNR Slot
    Look on your board for a white sticker as indicated by the image attached. If it isn't there, check to see if there is something actually printed on the board usually around in the same area as your BIOS chip is located.
    For examples see the pics below:
    I hope it helps.
    If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
    All the best.
    Mar 29, 2010 | ASUS P5N32-E SLI PLUS (0610839148967)...
    Mother board
    Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
    Pros: None noted, given available product data.
    Cons: None noted, given available product data.
    Suitability: A compact motherboard, suited for small computers.
    Value: In view of its inexpensive price, this motherboard has great features for the money.
    Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
    XFXg31
    General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    Power led connector problem
    [ 1] [ 2] [ 3] [ 4] [ 5][ 6][ 7][ 8][ 9][10]
    [11][12][13][14][15]16][17][18[19][20]
    Robert,
    Above is a rough diagram of the Front panel connector on your Motherboard. Your Power LED should connect to pins 1 & 3 if this connection does not have the power LED come on with the PC then reverse which wire you've attached to those two pins. (As LED's are polarized they must have current flow in one particular direction to operate) Pins 11 & 12 are your Hard drive activity connector
    Hope this helps you
    Dave
    Nov 11, 2008 | ASUS P4P800-VM Motherboard
    Male moniter plug on both moniters(every one in the world) and motherboard
    That Male connector is a serial port not video, you need to get a video card and plug the monitor to this card.
    thanks for rating
    Jan 10, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
    ASUS P5BVMSE Motherboards Logo
    433 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Marvin
    Marvin
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
