Hi I have a Samsund Washing Machine SW65ASP2 triflow and i put a load on and it went find. Went to do another load and it came up with Code DE
  • saraschmerl Dec 31, 2008
    Thanks for trying it was the magnet in the door which had fallen out
  • 17 Answers
DE is a door lock error it could be the door hasn't been shut firm enough or the door lock may have failed. Sometimes the pin that goes through the handle and ****** comes lose the door would have to be taken apart to check for that and in some rare cases the main module can be faulty.
Posted on Dec 21, 2008
Code dE
As Far As I Am Aware That Is A Washing Machine Door Error Code
Apr 21, 2014 | Samsung SW62ASP Top Load Washer
I have a samsung washer sw65asp2 faulf code 1E
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Samsung SW62ASP Top Load Washer
Samsung SW65ASP2 top load washing machine only lets water in slowly.
there may be an obstuction at the wateer inlet valve turn off your water and remove the hoses and check for anything that would be restricting the water flow if this does not work you may need to replace the inlet valves.
Jan 31, 2010 | Samsung SW62ASP Top Load Washer
Washing machine Samsung Triflow SW65ASP not spinning anymore
I had the same problem it was the pump filter on the back. unscrew it and clean it. That worked for me.
Jan 19, 2010 | Samsung Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
My machine has a code and is full of water
can you provide the full model # and also the full error message?
Sep 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
Check the brushes in the motor.
Jan 28, 2008 | Washing Machines
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
