SOURCE: acer 3500 mouse touchpad totally frozen
have you tried updating the driver
or go to control panel and mouse and check the settings in there
does your laptop work with a normal mouse
SOURCE: Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
SOURCE: Acer Aspire PC Notebook 5315 touchpad not working.
Hey in the control panel, go to the mouse, then look for the properties that have a PS/2 compatible mouse, you can change its settings there by sellecting other compatible mouse instead of PS/2, and also there is a settings or a check box that says the onboard mouse of your laptop will be disable if a usb mouse will be pluged.hope it soved your problem, :)
SOURCE: acer aspire 5517 touchpad doesn't work. We have
On my Acer Aspire 5534, up above the keys there are 2 buttons that are side by side. one is to turn the wireless off and on and the other one is to turn the mouse pad off and on.
SOURCE: how to disable touchpad
Dear friend please press FN+F7 ( sign of touchpad) Its will locked then. When you want to use it again press same key. Follow the sign which is you press with FN key.
Thanks & waiting for your feedback.
