Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Replacing the 3 fuel lines
Curved shaft gas trimmer all 3 fuel lines have come off as they have crumbled and I don't know which hose goes where
  • henry139 Jan 21, 2009
    replacing the the 3 fuellines
  • james2034 Jan 21, 2009
    My fuel lines on a 700r trimmer disolved. I am attempting to replace the 3 lines, but do not know where to run them.
    Scholar:
  • 149 Answers
Check my postings 3 days ago it give a good run down
Posted on Jan 15, 2009
The trimmer starts fine, but wont stay at high speed runs for a while then shuts off
Before pulling the carb apart, drain the fuel fit a new filter in the fuel tank, check the fuel hoses up to the carb for splits, cracks or leakage, replace if required.
Jun 23, 2012 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you get the fuel line connected to the fuel filter nipple on the bottom side of the gas tank on the Ryobi 725r gas trimmer?
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
The fuel lines were brittle. I need to know how they hook up to 33 cc
The typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Dry rotted tubing on my weedeater blower.
Have it replaced at a lawnmower repair shop.
1.) Have them check the grommet (black round rubber like a thick coin with 2 or 3 holes), replace it if it is crumbly. It holds the fuel line and the fuel vent line - if your trimmer has it. Grommets on the average cost about $6.00. Not all trimmers have fuel grommets, some of them only have holes right on the fuel tank. 2.) Replace the fuel line with Tygon fuel line hose. Tygon can withstand UV light, petroleum, high and low temperatures while retaining its shape. Just make sure the replacement tube is of the the same inside diameter. For a small piece of Tygon hose, ave. cost no greater than $8.00. 3.) Replace the fuel filter. The one inside the tank, connects to the end of the fuel line. Fuel filter, good ones are about $4.00.
Aug 23, 2009 | Garden
Fuel line connectors pushed into fuel tank
I slice the new hose like the end of a medical needle, like a long v. A little lubricant on the hose will help as well, Cut off enough that you can thread up throught he filler hole, there should be a filter on the end of the hose. Do this obviously with the gas tank empty, when you turn upside down, the old hose should fall out or be available to grab with needle nose pliers. I hope the helps.
Jul 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 768r fuel line
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Mar 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 700r gas trimmer, replace old fuel lines
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
432 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
