Mpio FL300 MP3 Player
Problem for Mpio FL300 MP3 Player
Won't turn on
By Meghan44 on Apr 03, 2007
When I plug my mpio in to recharge nothing is happening?? I'm using a different computer then originally, could the port be the problem?
Same Problem
Oct 17, 2008
-   computer doesnt detect the mpio mp3 player at all,what should i do?-   Guest
Best Solution
posted on Oct 08, 2007
Very Helpful)
Tech data
Rank: Master
Rating: 94%, 31 votes
either you got a faulty surface mount regulator IC or you got a corrupted flash memory. Try pressing play button, then alternately press volume down (-) and Rewind (<<) buttons. When the "FORMAT? Press Menu" appears, press MENU BUTTON. A LOW LEVEL FORMAT will be in progress. When it's done, reload firmware recovery using MPIO Utility.
If however you nothing appears on the screen afteryou pushed the play, rewind, and minus buttons,or still it doesn't power up, you've got a faulty regulator IC. It is the five pin chip colored black with the markings "PHK" (use a magnifying lens to confirm) located on the left besides the battery connector (facing up, with the earphone jack on the top). If you had micro soldering skills, then you can remove the chip and replace, if you can find a replacement...
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jul 17, 2009
Somewhat Helpful)
wefwe875
Rank: Apprentice
Rating: 75%, 1 votes
TAHNKSSSSSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Was this helpful?
Yes
No
Popular Solutions for Mpio FL300 MP3 Player
Questions and Unsolved Problems for Mpio FL300 MP3 Player
Do you recommend Mpio FL300 MP3 Player?
Answer
Answer
i plug my mpio mp3 player into my computer but it doesn't show up in the my computer area do i have... (More)
Answer
Computer does not recognize/find FL300. MPIO Utility just gives error code.
Answer
I CAN'T GET MY FL300 PLAYER TO INSTALL ON MY VISTA CAN'T FIND THE DRIVERS FOR VISTA
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , FL
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
