Monitors
Problem for Monitors
Generic problem for all Monitors
Computer monitor keeps auto adjusting scr...
By dorand23 on Dec 20, 2008
The monitor keeps constantly auto adjusting the screen when the computer is in use. The is no obvious way to disable this program.
Comments:
Dec 21, 2008
- I have a Samsung SyncMaster731N black 19" monitor. When I swicth on the computer it keeps auto adjusting the screen. There seems no way to disable the auto adjust.
Clarification Request
Posted by conniefisch on Dec 20, 2008
From the title of the question, I see that your monitor is a Samsung.  What model number is it?
Same Problem
Jan 29, 2009
-   I have the same problem that just started today. The power has gone off during the night and now every time I change screens the thing auto adjusts. Any idea how to turn it off? -   Guest
Jan 11, 2009
-   Hey, I have a Dell Computer Monitor im not sure about the screen size but roughy below 19" and it constantly auto adjustes for no reason aswell-   Guest
Best Solution
posted on Apr 12, 2009
Very Helpful)
matnels
Rank: Apprentice
Rating: 100%, 1 votes
Try this: Right click on your desktop. From the pop-up menu, click on your graphics display (NVIDIA etc.) and then on the monitor you have (Dell1234 etc), or if not listed, click on 'properties', then the 'settings' tab, then 'advanced', then select the graphics display tab (NVIDIA etc.) Go through all the menus and click 'restore to defaults' and 'apply'. Hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 21, 2008
Helpful)
crichner
Rank: Wiz
Rating: 80%, 218 votes
Check that your monitor cable and power cables are secure at both ends. Appears that the signal is weak or intermittent
Was this helpful?
Yes
No
Solution #3
posted on Mar 25, 2009
Somewhat Helpful)
hartop901b
Rank: Apprentice
Rating: 75%, 2 votes
I have benq lcd monitor that also keep auto adusting, I found that the poroblem was the ground conection from the front button circuit that had a bad connetion. So open the rearpanel, and try to fix the ground connection...
Was this helpful?
Yes
No
Solution #4
posted on Feb 03, 2009
Not Rated)
Dae Nyte
Rank: Apprentice
Rating: 0%, 0 votes
I don't know if this solution is credible to all monitors with this problem.... but have a gateway monitor and it kept doing that annoying "auto processing" flash while i worked...but i figured it out...for some wild reason i held down both the "auto" button and "contrast down" button and it fixed it. it will take a couple of tries but on a lucky push I did it and it went away and i havent had a problem since...I hope i have been a little help :)
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
I have an HP w17e hooked up to a DELL..and there is no sound? why not?
Answer
Yesterday lines down the right side of our monitor appeared. How can I solve this problem?
Answer
I would like to use my SONY SDM-X72 LCD monitor like TV. Is it possible and how?
Describe your Monitors problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
