If the shaft from the motor is not securely connected to the fan, although it is turning, it may be slipping. Check that the set screws are tight between the motor shaft and the squirrel cage fan.
Otherwise, it sounds like you have duct problem. A rodent may have chewed a hole in the duct, or the connection between the and the delivery duct, or the connection between the delivery duct and the floor or wall grate has become disconnect. (This last is common, a screw holding the duct to the floor grate has come loose or the duct tape has come loose from gravity pull down on the duct to grate connection. If you have a basement or crawl space you have have to inspect that the duct work has not come apart.
I've found several different styles & manufactures of satin nickel bath hardware at Home Depot and Lowes. Soap dishes,towel rods,toilet paper holders and even matching toilet flush handles.
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here:
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
