Question about Sharp EL-2630PII Calculator
Paper Stuck in Printing Calculator
4-3-07 Our accountant got some paper lodged in her Sharp EL-2630PIII & as secretary it's my job to try and be "Mrs. FixIt. I've got most of it out of the "feeding chamber" where you insert the paper but short of figuring out how to take it apart I do not see a way to get the rest of the paper out- or how to safely take it apart for that matter. Someone please help! Thank you in advance. ~M. Schenck in Cranston, Rhode Island, USA
Maybe the commenter should get a life and do something else besides trolling sites like this sniping at people trying to do real work.
We came here to see if someone had solved the problem...sure, we're smart enough to buy a new one, but why throw out something that can be fixed for a few minutes time or a few dollars investment.
My problem ended up being a small piece of paper caught in the paper path...working paper through it several times cleared the issue. Hope that helps someone.
Posted on Apr 20, 2010
Hello dude get a life and buy a new one duhhhh!
Posted on Dec 24, 2008
  • fagitory Dec 24, 2008
    yes thats good i got a new one
Paper does not advance properly on my sharp el-1801p calculator
probably there is paper underneath the printer..if you are handy you have to open the printer underneath to take stuck paper out.
or take apiece of clear place ,that can enter where you pass the paper.and let the plastic come the other side out.
probably it willcome with anything that is stuck beneath the printer
M.P
Sep 11, 2014 | Sharp EL-1801P Calculator
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
I have replaced the ribbon twice now but the print still comes out very light
I'm having the same problem. This is my second Sharp EL-2630PIII calculator and the first one did not have this problem (prior job). I can change the ribbon and the print is still so light I cannot scan it as part of my work papers... which is a huge problem as an accountant.
May 21, 2014 | Sharp EL-2630PII Calculator
CE button doesn't clear on my SHARP EL-2630PIII
CE stands for Clear Entry. It clears the number that one just entered. To clear the results of a previous calculation use the key AC, if calculator has one. Otherwise try pressing the CE key twice or enter 0, because that is what the clear button will do.
Sep 30, 2013 | Sharp EL-2630P Calculator
Sharp el-2630piii calculator setting to two decimal points
Slide the "F 6 3 2 1 0" switch to the "2" position.
Feb 28, 2013 | Sharp EL-2196BL Calculator
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Jun 23, 2009 | Sharp EL-1801P Calculator
Sharp EL-2630PII Calculator Logo
759 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
