Question about Elna Sewing Machines
Elna jammed with needle through fabric into plate
I am in the middle of sewing fabric and the sewing machine has jammed with the needle through the fabric into the base plate (sorry, don't know the correct name for it). The wheel at the right hand side will only turn back and forwards a tiny amount before being completely jammed. I have removed the thread, and removed the bobbin from underneath, but that hasn't made any difference.
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Posted on Mar 07, 2009
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
I have an Elna explore 340 sewing machine. Fabric jammed while i was sewing. how do I remove fabric
Carefully cut any thread, turn the hand wheel gently to lift the needle up. Lift the presser foot up from the fabric, if the fabric is jammed in the feed dogs, and as the metal plate, take a screwdriver (some machines come with a special one). Unscrew the metal plate and use a seam ripper to carefully pull out the fabric or loosen them from the feed dogs.
Oct 12, 2018 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
What is the rght tension for The Elna Contessa 410 sewing machine?
Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Feb 24, 2017 | Elna Sewing Machines
My very old little elna lotus (not sure if zz or sp) has suddenly jammed solid with the needle down through a piece of material. I can't move the flywheel at tall and I can't free the materia
Try unscrewing the needle, and then pull up the plate, and sort outthe threads very carefully with a quikunpick. When starting to sew, have slightly longer threads, make sure they are behind the needle, and hold them in your left hand. Especially when sewing very fine fabric, start slowly until you are sure the threads are forming properly, then it's OK to speed up. Use your ears, if it doesn't sound right, stop immediately. If you are going to use fine slippery fabric, be sure to do a trial piece first, rather than muck up your project. Elna machines are lovely to use, I've had one for over 40 years, still in daily use. Oiled with one spot of oil each time I use it, fluff regularly cleaned from underneath with the little brush supplied.
Apr 15, 2013 | Elna Sewing Machines
I have an Elna xe35, everytime I use it, the thread Jams underneath, how do I stop this?
try changing the needle--normally flat side goes to the back of the machine
also make the needle & thread will work for the fabric being sewed
make sure the bobbin is turned the right way & inserted correctly in the bobbin case
make sure that the thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for loose thread & lint
Apr 02, 2012 | Sewing Machines
Elna 9000 bobbin problem
try changing the needle,,make sure the needle & thread & fabric are correct for each other
it's also possible that when the needle gets jammed or broken that the machine can become out of time
and would have to be retimed at a sewing machine shop
Apr 01, 2012 | Elna Sewing Machines
Sewing Machine fault
Perhaps the manual would be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjv-KjEyNLXAhXDwFQKHZJtD4sQFggmMAA&url=https%3A%2F%2Ffiles.tv-sewingcenter.com%2F2015%2F04%2Felna-sew-fun-instruction-manual.pdf&usg=AOvVaw08q0vhbb6YSyyVVTwMCUKH
ELNA Sew Fun Instruction Manual
The feed dogs on your machine do not drop. Instead, the machine has a darning plate that covers the feed dogs (see the accessories listed in the manual). If the darning plate is installed properly, it should prevent the feed dogs from contacting the fabric.
Make sure the stitch length dial is set @ 2 or higher. This will insure the fabric will move as the machine stitches.
Nov 22, 2017 | Elna 2007 Mechanical Sewing Machine
Embellishine machine
To my knowledge this is requires a special machine, a felting machine. Brother, Janome, Babylock sell models
Oct 13, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
55 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
toolmanw5687
Level 1 Expert
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
