Hi. The most common cause of overheating is a build up of dust inside the laptop, mainly on the fan blades and the heatsink, This dust also collects around the exhaust and becomes matted together like a quilt, blocking the hot air from escaping the unit, causing the laptop to overheat and shut down to protect the CPU from damage. You could try to clear the blockage with a can of compressed air, although in many cases this does not work. It all depends on the level of blockage. If this does not work, and if you feel confident about taking the laptop apart to remove the blockage, you could try this...
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm Information courtesy of
irisvist.com. Hope you will find this helpful.
