My computer when im on ebay displays the following:error code 400 404 500
  • 111 Answers
Error code 404 is page not found it is either been moved or deleted
contact ebay
Posted on Dec 21, 2008
How do I fix fan wont shut off
In front of the 04 code, what is the "F" code is needed for help you. There are 4 different possible answers for this issue.
FAILURE/ERROR DISPLAY CODES Before proceeding with any corrective action, perform the following steps to enter the Diagnostics mode: 1. To recall last failure code, if not displayed, press the Cancel key to place the range in an idle state. 2. Press the Cancel and Start keys in the following order: CANCEL, CANCEL, START. 3. Verify the error code displayed on the control by observing for longer than 1 minute. If the error returns, use the applicable procedure listed below for the actual error code that is displayed.
With this information, I can narrow down the cause and possible repair on you unit. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 11, 2016 | KitchenAid Kitchen Ranges
Asus maximus iv gene z error code 45
A Windows Error code 45 will display or populate a error message that looks similar to the following:
Currently, this hardware device is not connected to the computer. (Code 45)
The device is not present or was previously attached to the computer. If Device Manager is started with the environment variable DEVMGR_SHOW_NONPRESENT_DEVICES set to 1 (which means show these devices), any previously attached (NONPRESENT) devices are displayed in the device list and assigned this error code.
What is the solution for this then?
To fix this problem, reconnect this hardware device to the computer.
No other resolution is necessary.
Visit also asus, and look for any driver updates for the mainboard:
http://www.service.asus.com/#!downloads/c1wax
Good luck
Jan 24, 2013 | Computers & Internet
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
CODE 10 ON TSST l632@ VISTA os
This is from Microsoft and is from their code explanation page.
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
Jan 15, 2010 | HP Pavilion DV6700T Notebook
Whirlpool Duet F02 code
Hello there
You are pretty close
here is the fauilt code and the procedures that you can take to troubleshoot Hope this is very helpful for you
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CODE 10 ERROR
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Mar 30, 2009 | Samsung Super-WriteMaster SH-S183L Burner
W810i display backlight problem
You will have to replace this off eBay Im afraid, I have one in the shop but I would'nt be selling it on here or private. It would be listed on eBay or for my customers.
Feb 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
GE Dryer error code E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
Mar 16, 2007 | GE DBVH512EFWW Dryer
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
