Question about GE JES1358 Microwave Oven
Up in smoke
My wife was cooking a "baked potato" in our microwave. She had placed it on a paper plate on the turntable. She went outside for awhile to take care of what she was cooking on the grill. When I went to the kitchen, the room was full of smoke and the paper plate as well as the potato was we burnt black. Since then the microwave has not worked. Is there any hope for the microwave? I would like to fix it myself if there is any hope for it.
  • GE Master
  • 9,098 Answers
The unit has a flame sensor, called the cavity thermal cutout or thermostat. Chances are yours is bad now due to the fire. But it may also be the thermal cutout or thermostat. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Apr 10, 2007
    Genius:
  • 1,074 Answers
Yes there is hope have a tech check your set or buy a magnetron to replace the existing one make sure you discharge the high voltage cap it store letal voltage.be careful if you are going to do it yourself.
Posted on Apr 04, 2007
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
While using the Bake Potatoe setting the code F6 came up on the display and the light went out and the machine was making a humming noise.
F6 on a Whirlpool microwave means your cook relay has shorted.
We can repair that with our $39.95 service (details here) or you can order a new control circuit board from the Pros here.
Jan 24, 2011 | Whirlpool Microwave Ovens
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
Frigidaire PLMV169DC (SS) 1000 Watt Microwave Oven/ Not working
REMOVE THE CABINET AND IT SHOULD BE CLOSE TO THE POWER INLET ON THE MOTHERBOARD IT LOOKS LIKE THE OLD GLASS TYE FUSE BUT MADE OF CERAMIC. GO TO www.repairclinic.com ENTER MODEL NUMBER, SCROLL ALL THE WAY DOWN N CLICK THE RED 100. FROM THERE LOOK FOR PART 634759 1055598 634750 1055589 1469078 ONE OR MORE OF THESE COULD BE THE CULPRIT START WITH THE LINE FUSE.
Apr 17, 2009 | Frigidaire PLMV169DC Microwave Oven
Fire in Microwave Using Sensor Control for Potato
Please contact your home insurance to have the problem logged as a failure of the microwave. The insurance company will most likely help you with the smoke damage to the house and will contact the manufacturer to get their money back... there might be an issue with the manufacturing of these appliances.
Jan 04, 2008 | Amana ACO1860 Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
GE JES1358 Microwave Oven Logo
167 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
