Question about GE Profile 30" Slide-In Gas Range - Stainless-Steel
New ge908 slide-in range
The filler strip in rear is not wide enough. does ge make a 31 or 32 inch rear filler strip? The accompanying strip was only 30 inces wide. the strip is needed to close the gap with the island granite
    Scholar:
  • 111 Answers
The 30" is the widest you can get. I suggest getting a piece of stainless steel and having a metal shop cut and smooth the edges
Posted on Dec 20, 2008
Once we leveled our Electrolux slide in gas range, using it's feet, it created a gap between the left side and the countertop. Is there a filler (removable when necessary) we could use for th
Thank you for your post, Wendy Berg!
I understand that you are searching for a filler piece to go between your Electrolux range and countertop. I was unable to locate any type of filler piece I see the manufacture has a side trim kit, rear filler panel, and backguard kit but nothing specific to your request. I hope this information is helpful. -Matt
Sep 27, 2014 | Electrolux EI30GS55LW | 30" Slide-in Gas...
My GE range is only 10 months old and has rust spots forming on the inside bottom, what causes this? This is also the second GE range to do this in the last 4 years. Are GE ranges known for this?
Rust spots will only occur after the finish is damaged or just simply fail.
This is not common for GE or other manufacturers. But I would not be surprised in the quality of workmanship is slipping for all manufacturers.
Oct 20, 2013 | GE JB705TTCC Electric Ran Freestandin 30...
Burner will not get hot enough
When the burner arced out it probably also ruined the switch. Most switches on a standard electric range have 5 wires. 2 wires to the burner. 2 hot wires from power and a smaller wire which connects to the indicator light marked P. It is easy to test the switch Unplug the stove. Turn the suspect switch on wide open. Check for continuity between the 2 terminals going out to the burner marked H1 and H2
If you cannot get a reading then the switch has failed. Note: when replacing the switch usually on most stove the replacement will not be or look like the original HOWEVER it will still have L1 and L2 H1 and H2 and P but the terminals are not always in the same order. If you fail to correctly connect the new switch you will fry 2 switches when both get turned on. Ouch!
Aug 30, 2012 | Kitchen Ranges
Do you know the dimensions of the GE jvm230 over-the-range microwave oven?
Just measured mine as I'm looking to replace it.
30 inches Wide
15 inches high (front)
16.5 inches high (rear)
13.5 inches deep
Nov 18, 2010 | GE JE1540 Microwave Oven
Maintop Filler Kit for GE slide-in range JSP42SNSS
Maintop Filler Kit for GE slide-in range JSP42SNSS was missing. I am not sure why your response to a simple question (in a form of a question/offer to sign up for Premium Assistance Plan) referred to a different model number for a gas kitchen range (mine is electric!).
I fixed it myself. I bought a piece of 2"x2" sheet metal angle, painted it black and attached it to the wall behind the range to close the gap.
No need to bother your "Elite Experts" and pay $19.99.
Aug 28, 2009 | GE Profile JGS968SHSS Gas Kitchen Range
Over The Range Microwave new models too tall need under 15 in hig
cut the cabinet off. a cabinet maker can do it and you can tell if they ar good
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Nov 13, 2008 | GE Ovens
Electrolux Slide In Electric Range doesn't fit to the wall?
We have the same Electolux range.....it is supposed to fit about 2 inched from back wall......your granite installer will have to fit a piece of granite behind the range. Yes, it is proper to have the plug installed. The plug is not part of the range package and will have to be purchased seperately if your installer does not use the plug from your old unit.
We are on our second slide in with wave touch controls.......we hope you have better luck that we've had. Ceramic cooktops do not seem to be level on all units. The bottom oven has locked up on both ovens and cause burned foods.....Electrolux has problems that aren't acknowledging as yet..........good luck
Jul 02, 2008 | Electrolux 30" Self-Cleaning Slide-In...
GE Profile gas range
I would highly suggest using the filler strip or do not use the oven in self-cleaning mode. You may be able to get the one previously used with the oven if there was one.
Sep 08, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile 30" Slide-In Gas Range - Stainless-Steel Logo
404 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
