Bike shows error 37 which is immobilizer transponder. 1 day everything was ok, the next day bike not starting. immobilizer not reading the key, I tried 2 black and a red key as well. nothing. when i use the code card and start the bike moving the throttle than bike starts. using key is not starting. anybody knows how to sort this out ? Thanks
SOURCE: 1999 Ducati 996 Will not start
yes, it is either the ignition relay which also runs the fuel pump or the feul pump itself is either locked up or just has gone bad. you should charge your battary then try it again and that does not work you can try hitting the feul pump with a small hammer after you have removed it from the tank, this sometimes will get it going again. i've had brand new bikes just out of the crate need a shock to the fuel pump to get it going. it's a contact problem between the brushes and the commutator of the starter motor. something else to look at before toy take the pump assembly out of the tank is to varifey voltage at connector body of the fuel pump under the tank. find an electrical diagram to find out which wires send the voltage to the pump, if you have voltage there at key on then you will have to pull the pump out. hit it with a small hammer on the body of the pump motor and plug the assembly back into the bike and hold the pump upright over a small container to catch gas that may come and turn the key again. if it does not run you will have to buy a new pump.
SOURCE: Battery Trouble! Ducati 749 dark
you need to get a battery tender, and when you put your new battery in it has connections that will stay on your battery and you just plug it in after you are done riding and cleaning her. oh one more thing when you get a new battery you need to charge it for 8 to 12 hours before using it, they are not like a car battery buy it, put it in, and go, you have to charge them up first. The tender should keep you battery charge all winter long. I hope this helps you. One more thing, 749's do not like weak batteries as you have found out. Buy a new one, install a tender and and use it, the battery will last much longer.
SOURCE: 2005 CRF450R Hard to start and wont idle
Hi
I would suggest that you have the valve clearances checked.
Also, check that the carb is clean. Pay particular attention to the PILOT JET as this opperates the idle circuit.
Jon
SOURCE: 600 honda hurricane will not start
Be sure the kill switch is off. Check the side stand kill switch. Sometimes they go bad and kill when up AND when down. Hopefully the problem is constant instead of intermittent. Intermittent problems are the worst to find. Both coils are not likely to go bad at once. CDI yes, coils no. How good is your battery?
SOURCE: 2002 cbr 954 red light on gauge blinks
sounds like the engine management fault code signal. there is a free download service manual here. with it you should be able to decifer it http://www.carlsalter.com/motorcycle-manuals.asp
