Question about Viking VGSC306-4B Gas Kitchen Range
My viking electric oven does not have accurate temperature
How can I calibrate oven temperature control on Viking DEDO oven so the dial provides the correct temperature?
  • Anonymous Jan 24, 2009
    I have the same problem.
  • Anonymous Apr 12, 2009
    I have the same problem...if I want something to cook at 350...I have to set the oven temp at 400
  • 42 Answers
How bad is the temp off?
Posted on Dec 21, 2008
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Oven wont bake at the right temperature
Sorry for the cookies have you tried going to the viking web site and downloading a manual on your oven. Usually they will explain how to calibrate the oven. Hope that this helps if not let me know please thanks
Dec 23, 2008 | Viking VESO176 Stainless Steel Electric...
Lengthy preheat time
Hello. I am a Viking factory trained tech. and that is actually a normal preheat time.
Now if it undercooks that is another problem.
You may need your thermostat calibrated or replaced. If you think you are up to calibrating it yourself let me know. If it is the kind that doesn't have any white silicone in the center of the knob stem then it is quit a pain in the neck, but if it does have the silcone then it is a lot easier.
Dec 03, 2008 | Viking VESO176 Stainless Steel Electric...
Viking DED0530TSS oven calibration?
With a small screw driver and a steady hand. Set the knob to the temp u want then pull knob off. Inside the stem there is a little screw. Try and regulate it slowly also allow it enough time to reach the desired temp. Good luck.
Oct 29, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
My oven runs about 100 degrees hotter than the dial says
Check the temperature select knob. On the inside of the knob there should be an adjuster.
The temperature probe may be the faulty component since this is an integrated machine.
Jan 22, 2008 | Viking DEDO205 Stainless Steel Electric...
Viking VGSC306-4B Gas Kitchen Range Logo
1,405 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
