Question about Janome 2049LX Mechanical Sewing Machine
My machine locked up
My Janome sewing machine is less than 4 years old. It has frozen up on me. I don't even get the motor to budge, by hand or by pressing my foot on the peddle. I was in the process of a sandscarf sewing project for the folks in the military and the needle stopped in place. I wasn't able to continue. Can anyone help? Finding a sewing machine repair service locally is proving to be a problem. I need my machine to work.
  • 1 more comment
  • Anonymous May 21, 2008
    My Pfaff Sewing Machine has frozen up. I can't get the wheel to move forward or backwards. When I try to sew, the motor works but I can't get my needle to move.
  • Anonymous Nov 12, 2008
    I have the same problem with my Pfaff vaimatic 6091. Did anyone solve the problem?
  • Anonymous Mar 13, 2014
    Even though hand wheel does not turn manually...the machine sews if I use the foot feed. Will I damage my machine if I continue to sew?
Have you ever oiled it?
Posted on Jan 09, 2008
    Genius:
  • 1,074 Answers
Check www.partstore.com they might be able to help you with manual.but you need to change the motor ot you machine and it will work.good luck
Posted on Apr 04, 2007
SOURCE:
Where would i get a zipper foot for 40 year old janome sewing machine
fortunately manufacturers take a long time to change walking feet so go to a janome sewing machine repair shop and they may have one that covers a range of years
Oct 11, 2016 | Janome Sewing Machines
Bernina frozen, nothing moves
it's possible that something has broken or come loose inside the machine and the machine needs to be checked..
Jun 26, 2013 | Sewing Machines
Needle won't move.....
I cannot find anything about "American Standard Sewing Machines" in a google search. Thoughts: sounds like your gears are frozen. I would take it to a different repair shop. Try to find an older person to repair it. Never under estimate the old guys.
Aug 22, 2012 | Sewing Machines
Dogs motor?
Does it have a stitch length dial which ranges from 4 down to 0 and then into negative numbers? If so, the negative numbers will be reverse stitches. Some machines have this functionality and its very happy for doing mending or stitching in awkward places to sew backwards without having to hold the reverse button.
However, if yours is only sewing backwards when stitch length is set to 2, 3 or 4, then its probably a drive problem internally. Don't think your machine has a seperate motor for the feed dogs, probably a gear driven shaft in the free arm.
Dec 06, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
My Janome memory craft 8000 will only sew backwards and the screen shows step motor error. the machine is 19 years old. Is this fixable?
step motor error may mean the embroidery arm is out of position gently push it back home towards the machine and see if this helps. If the mother board is gone, they will not be able to replace it as its so old, but you may be able to get an 8000 or 9000 on ebayso you can still use your discs if you don't want to get a new machine
Aug 09, 2010 | Janome Memory Craft 9000 Computerized...
Frozen machine
Hi this is techcrazy
the motors in ur sewing machine is not runnin because there is no proper rotational motion inside the motor of sewing machine.so one way of rectifyin is replacing the old pair of magnets with new ones..which may prove costly.so if possible my sincere advise is to go in for a new one
please do rate me on this solution
Feb 02, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Oiling my Janome Gem Gold
Janome Gem are self lubricating. Silicon is embedded in the gears and releases as it runs. If the machine is put away and not run every so often it will lock up. The hand wheel may have thread caught up around it. The Gems aren't assembled to be dissembled except to change the light bulb.
Jan 16, 2009 | Janome Jem Gold 660 Sewing Machine
Janome 2049LX Mechanical Sewing Machine Logo
827 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
