Question about Hitachi 53UDX10B 53" Rear Projection Television
Replaced Convergence ICs, now the TV is beeping when I plug it in
About a week ago, the TV was ghosting too much green.  I replaced one of the convergence ICs with a STK392-110, turned the TV on, and there was too much red.  I replaced the other IC with an STK392-150 (the 110 and 150 were already on the TV, I thought I'd just replace them with the same numbers), and now when I plug in the TV, I get beeping from it.  I look inside and when its plugged in, there are 2 green lights beeping on the left of the convergence board.  Does anyone know if it's possibly a fuse? I checked the circuit boards for shorts, and I didn't see anything significant. Thank you in advance for reading this.
Slinteriors
  • 8617 Answers
SOURCE: Hitachi 53UDX10B Power Light Flashing after convergence IC replacement
C603 is a polyestor capacitor 0.068UF-FEB 50V part number 0880047R S901 is the power relay ALKS329 the part number for the relay is FJ00142 . I recomend checking the pins on the ICs to make sure they are not bridged. If you need more assistance let me know. Vance Baldwin should have the parts if not you may have to order through hitachi
Posted on Jun 06, 2008
SOURCE: Convergence problem
hello I would like to see this post thanks
Posted on Jul 15, 2008
welcomejee
  • 10594 Answers
SOURCE: Removing the JK07132-A convergence board
Unplug TV from ac outlet for few hours, this will discharge caps in circuit boards and you can take out desired board after unplugging connectors.
Always Be Careful while doing repair in TV.
Posted on Dec 26, 2008
  • 4234 Answers
SOURCE: Akai/Samsung PT4299HD Convergence Problem
Try resoldering the pins on the ICs first. If that fails to resolve the problem, change the IC responsible for RED. You should be able to determine that from the service manual. In that area you should also see either fuses or low valued resistors that feed the STKs. Check those as well.
Let me know if you need further info.
Dan
Posted on Feb 13, 2009
Ecollier2012
  • 3459 Answers
SOURCE: poor colour balance
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 08, 2009
Hitachi 51f500 wide screen hidef monitor,red green ghosting on right and left sides of screen
Ur tv convergence are dead.U know how to do soldering?U must replaced 2 STK convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Apr 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Picture has green and red ghosts. went to magic focus and it will not continue thru the red focus, then a #5 is on the bottom of the screen
Ur convergence is dead.Know how to solders?Must replaced two convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.Tv shop will cost u $300 dollars for parts and labors.
Jan 26, 2010 | Hitachi 51F500 51" Rear Projection...
HAVE A JVC AV-56WP30 REAR PROJECTION TV THAT THE PICTURE APPEARS IN A BOWED SHAPE. THIS TV WAS JUST REPAIRED FOR THIS PROBLEM ONE WEEK AGO AND IN 100 MILE DRIVE TO PUT IN APARTMENT IT IS AGAIN NOT WORKING....
The convergence is dead,Must replaced Convergence ICs and resistors.Tell the shop to repair it again.They probally didn't replaced the ICs or resistors.This problems can't come back about a week,at 6 months i can understand.
Jan 11, 2010 | Televison & Video
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture and writing in 3d
replaced both convergence ics.the red green and blue colors are not converging.these ics are two big black ics.
Jul 28, 2009 | Sony KP-53V75 53" Rear Projection...
Convergence problems
TV Shop Repair ,I charge $285.00 to do this repair job in shop. Replace Both convergence ICs big black ics will have Part number on them STK392-560 also CK pico fuses around ICs they look like resistors in away but will be green or yellow 5amp/6amp fuses. For Parts call 1-800-223-3205 www.electronix.com You will also need white silicon heat sink compound to put on back of ICs.
Jan 03, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 47wx53 covergence issues
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Green double image
you need to replace both convergence ICs they are both STK392-110 and you can get replacement ICs at the following link and they provide free step by step instructions with pictures so you can do the job yourself. Heres the link.
Jun 30, 2008 | JVC AV-65WP74 Rear Projection Television
Hitachi 50ux57b
The green and blue ghosting is a convergence problem that is either bad connections at the convergence ICs or defective ICs. If you can solder, try resoldering the ICs. If that fails to resolve the problem, replace them. These ICs are large black ICs attached to a heatsink. They should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Dec 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
