Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Failing door latches
We have had 4 new door latches installed since 03/17/07. What could be our problem?
Put a coin under the latch on the top of the dishwasher. It will make a tighter seal
Posted on Feb 23, 2009
    President:
  • 2,692 Answers
Misaligned door. To much weight on door. Someone, maybe a child, hanging on door when opened.
Posted on Dec 20, 2008
Why does door open when in use anew lock has been fitted but does'nt seem to hold the door in the closed position comes open by it self tumble dryer then stops any IDEAS ?
Take a close look at the installation of the latching mechanism. There may be a slight adjustment that could be made to cause the latch to fully engage. I'm thinking the replacement was not placed in perfect alignment and the latch is failing to secure the door.
Look to see if there are slotted holes at the mounting surface indicating adjustment potential. Look on both pieces of the door latch as the mis alignment could be on either. Also check the door spacing across the top. Is it perfectly aligned or is it lower on one side by a half-millimeter of so indicating a hinge issue? A subtle change in the height of the door on one side could be the cause of mis alignment of the latch.
Mar 06, 2015 | Dryers
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
Why won't the door latch extend fully anymore? It extended fully for a few days after being installed.
Why does the interior knob or lever on my front entry handleset sometimes cause the latch mechanism to jam and the exterior thumb press to lock in place?If the front entry handleset is newly installed, the latch mechanism may be binding. If the exterior handleset is left sitting in the bottom of the bore hole through the door, the rectangular spindle that extends through the latch may be somewhat tilted and binding. This can be checked by loosening all screws, slightly lifting the exterior handle, and then tightening the screws before releasing the handle. This may make the spindle more level with the latch and eliminate the binding. If this does not resolve the problem, or the handleset has been installed for some time before the problem occurs, the latch mechanism may be failing and need to be replaced.
May 03, 2011 | Schlage FE365-CAM-ACC Lifetime Polished...
I have a 2008 chevy silverado crew cab and one of the door locks doesn't move
This is a very common problem on all chevy trucks for this year. The door lock solenoids are integrated into the door latch assembly, and are notoriously weak. They will work fine sometimes, others they just seem to barely move or not at all. You will need to replaced the door lock / latch assembly for the affected door.
Jan 27, 2011 | 2008 Chevrolet Silverado 1500 2WD
I push start and my dishwaher wont turn on. I have checked the other buttons and they work. I also turned off my breaker to see if that will help and it still doesn't turn on,
either:
  1. something blocks the door from latching or closing. Check, if anything is stuck behind a dishrack. try reversing lower rack. check if the door aligns properly and dishwasher is installed correctly
  2. latch switch failed/latch mechanism is broken. Disconnect dishwasher from power. Disassemble door, check latch, check latch switches for continuity
  3. touch panel or control board (less likely) is failing. replace if none of the above is working for you.
Good luck,
Vlad
First Choice Appliance
Sep 14, 2010 | Magic Chef CDB1500AW 24 in Builtin...
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
2001 Chevy s10 door won't latch
you need to remove the door trim. Remove linkage attached to latch. Usually the latch will be secured with 3-4 large phillips or torx screws. Remove old latch and reverse procedure to install new latch
Mar 28, 2009 | 2001 Chevrolet S-10
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Mar 24, 2009 | 1997 Lincoln Continental
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
177 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
