Question about IBM ThinkPad T30 2366 Notebook
Wifi Theres no button to turn the wifi on so i wasnt sure if it was a function key
  • scott011 May 11, 2010
    I need a question, and more info.
    What model? os?
    And is it a new laptop or do you already used it?
  • 126 Answers
There will be a utility on the PC. So say its an acer, you will find an acer toolbar. THis will have a wireless connect/ disconnect on. Make sure this is turned on .
Call 0845 20 20 118 for further assistance
Posted on Dec 25, 2008
My digihome wifi sayin disabled I can't go down or use button to enable it is there another way?
Hello Shannon,
Disabled WIFI can be frustrating. In a case like this, there is usually a button on your wireless router or laptop that DISABLES/ENABLES the wifi functionality. I would look for this switch or button and make sure it is ON. On a laptop, it may also be a FUNCTION key at the top of the keyboard. Just hold down the FN key and press the FUNCTION key that has a wireless symbol painted on it.
Otherwise, check the software on your device. Many wifi devices come with software that can be installed from a CD or the Internet. That software may also have a feature that can disable the WIFI.
Apr 29, 2016 | Computers & Internet
How do i turn internet off
the "Fn" key is usually orange accented, for all the orange functions. it stands for "function". make sure you are holding that function button down and press the button with the wifi tower or logo on it (usually on the F1-F12 keys at the top of the keyboard".
there might also be a physical toggle switch, that clicks on and off, look around the base of the laptop for something like that.
Feb 26, 2015 | Acer Computers & Internet
How to turn on wifi on a dell latitude e6500 that does not have a wifi button
1. Press FN + (function key with radio icon on it like F8)
2. If you runnning Windows 7 you can press WinLogo + X and turn on your WiFi. If you running Windows 8.1, click Network icon on taskbar then turn on your WiFi from there.
Make sure you have the right driver installed.
Jun 01, 2014 | Dell Latitude E6500 Laptop
Wifi settings not find wireless connection
make sure your wifi router is broadcasting so you can find it from your laptop. you may need the pass-phrase if you have that turned on. also, check your laptop to make sure the wifi radio is turned on. this is usually a button on the side or a function key on your keypad.
Oct 26, 2013 | Toshiba Satellite A105-S4004 Notebook
Wireless will not turn on
theres a switch that turns the wifi on/off
if that doesnt work, one of your function keys have a wifi on off switch. so hold function and press the F# key that has the wifi symbol on it
Dec 20, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Turning on the wi-fi, toshiba satellite l505-s5966
Turning on of wifi in laptops are usually done using the keyboard's function key and a Wifi button located from F1 - F11. Also a LED light indicator is placed somewhere in your Notebook, Which will tell you if your wifi is turned On/Off. So here is what you must do.
  • First try to locate your wifi button which is located from F1 - F11, it has a small logo like an Antenna with a signal wave on both sides.
  • Now when you found the botton, for example in "F5" , Hold and press the Function Key which is the "FN" then press the wifi button which is the "F5" in short presentation is this " FN+F5"
  • Remember to press it only once because pressing it twice will result in an off wifi. So be sure to press it only once.
  • After pressing it, a LED light should turn on, it is located somewhere in your notebook. When this light is on this means that your wifi is already turned on.
  • and Thats it.
Hope that my solution will help.Thank you for using Fixya!
Jul 07, 2011 | Toshiba Satellite L505-S5966 Notebook
I cant get any wireless signals because its says wireless capability is turned off it says to use the switch to turn it on but there is no switch. how do i turn it back on
Depending on your operating system, you can often just troubleshoot the problem and Windows will automatically turn your wireless adapter back on. If this doesn't work, it's likely that there's a physical switch on the laptop that needs to be in the "on" position otherwise it won't work. It may also be a function key combination. If this is the case, look for a little wireless symbol on your F1 through F12 buttons, then hit the function key "Fn" (usually right next to Ctrl) along with the appropriate wifi key and it should re-engage.
Mar 05, 2011 | Acer Aspire 4520-5582 Notebook
Compaq parcerio 2000 laptop web connection light will not come on
did you refer to the wifi light? actually wifi radio receiver is a manual thing and you should turn it ON and OFF manually. Im not sure with the model you described but try to look for a slide or push button with the wifi icon (an antenna with 3 waves). then try to see if the wifi led is lit. Another way, if your device is soft touch, then there is no hard press button for it. it will be a combination of FN + a function key (look at the function key with the wifi icon)
Sep 01, 2009 | Compaq Presario M2000 Notebook
Wi fi
Could you make sure that wifi switch is turned on.
This will be physicall button on the laptop of function keys combination that enables wifi.
If wifi switch is on you should be able to see wifi networks in range. IF you see networks but can not connect this will be network security issue. MAke sure that wireless network router is properly setup and security key you enter is correct
Jun 08, 2009 | Compaq Presario 700 470024-192 Notebook
Can not connect to wifi due to wireless switch
I assume you have a laptop or notebook. If you look closely at your keyboard, you'll notice a couple of keys next to the spacebar, usually on both sides, that have something like "Func" printed in blue or another color.
Now, if you look at the rest of the keys on your notebook, you will see that some have two
functions: the desired character key, and another, in the same color as that special
function key.
If you now look at the topmost row of keys, or the 'function" PF keys, it's likely that
they too have a second function, depicted by a small icon in the same color. The icon
you're looking for should look like a radiating antenna, and it may have on it (or elsewhere in the notebook) a small (usually blue) LED that comes on that comes on when WiFi is turned on.
The combo key action you refer to means that you should press the special function key next
to the spacebar first, and then the key that has the icon, to toggle WiFi on or off.
In other cases, there's a recessed button along the edge, either on a corner, or on the sides of the notebook, with a similar icon depicting an antenna of some sort, and it usually has an LED that comes on to indicate WiFi is active.
If all fails, your user's manual is the best source of information to find the key/key combination you need, since not all notebooks/laptops have these keys/buttons in the same place.
Apr 06, 2009 | Sony VAIO LT38E T8300 2.4G 4GB 1TB BDRRW...
IBM ThinkPad T30 2366 Notebook Logo
37 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
