Question about HP iPAQ RX3715 Pocket PC
Drained batteries, not powering up, next step?
I must have let my IPAQ batteries drain and had no power/nothing happen when I went to turn it on. I am now charging it via the USB cable. The orange light in the upper left corner is flashing, I assume this means it is charging. However, it will not power up at this time. Will I need to reset it after it is charged? Should I have any other problems gettting it to work? Why can't I turn it on WHILE it is charging? Thanks for any suggestions.
  • 102 Answers
For me I prefer charging the iPAQ using the usual cable, not the USB as I had some troubles with that It makes the battery drain faster. So Use a usual charging transformer.
Posted on Apr 05, 2007
I just purchased a toshiba mini notebook NB 505 it has about 5 hrs. of time on it. Went to turn it on the other night and when it starts up the screen was lite up but nothing else. I can not shut down...
It happens when the NB was not properly shutdown, NB was turned off due to battery drained and left idle or worst there is a problem with the mother board. You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it back from the reseller for replacement.
Mar 23, 2011 | Computers & Internet
The battery got flat and it went off but now after i've charged it it doesn't want to switch on again, pls tell me what should I do?
If its totally drained you need to wait for a couple of minutes while its being charge. T happened to my O2 Pocket PC before.Thanks
Jan 27, 2011 | Compaq iPAQ H3760 Pocket PC
My 307 peugeot wont start no power no lights noyhing was runnig fine all day untill i tried it this morning and nothing
May be the battery of your car is got completely drained. sometimes by mistake any of the car lights or ac or any battery consuming accessory remains on.And due to this battery gets completely drained and due to no voltage in battery the car does not start.In some cases the car does not gets turned off.If there is a problem in ignition switch circuit and this also drains the battery.Get the car battery voltage checked.It should be 12 volt if the battery is properly charged.This will let you know what is the problem .Also check the battery connections if its got loose then this can happen.------------- Thanks.
Dec 08, 2010 | 2005 Peugeot 405
I have a HP Ipaq H6340. I just got it from a
seem like all we get here are dead Ipaq.
why are you messing with this old device?
try a new battery, oops that costs money.
as does repairs on a device that has zero value.
why not mess with and old android phone, that has value.
ask here, be like only one playing Ipaq now.
https://h30434.www3.hp.com/
May 17, 2017 | HP iPAQ H6340 Pocket PC
Battery drained dead in ocld weather
Could be both batteries went bad.
1) I would take battery back to where you bought it and have them test.
2) Check, or have someone check, that battery power is not being used when the key is off and the car is not being used in any way. There will be a slight trickle of power use, but nothing that would wear the battery down in less than 3-4 weeks.
Jan 24, 2009 | 1993 Buick Century
Car won't start, battery seems drained.
hi
it sound like you ether have the light switch malfunctioning
or the head lamp relay is stack on ( pretty common ) or the battery has come to the end of it life , or poor connection ( corroded ) battery leads or and poor connection to earth
Dec 21, 2017 | 1988 Mazda 929
No power to Ipaq 3715
Just did this one, please refer to
http://www.fixya.com/support/t395532-not_turn
For the solution
Jul 29, 2007 | HP iPAQ RX3715 Pocket PC
3970 Stuck
Try this, take the ipaq off the cradle, turn the ipaq off (if you can), restart the desktop, put the ipaq back in thc cradle, turn the ipaq on, and restart ROM update again.
Sep 12, 2005 | Compaq iPAQ H3970 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
279 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
