Question about HP DeskJet 932c InkJet Printer
HP Deskjet 932C
I sprayed the inside of my printer to clean it out because the paper was getting jammed. Now the ink cartridges are locked to the right side of the printer. I pulled the ribbon attached to the ink cartridges and now it has unfastened. I bought this used and don't have a manuel. Please help me.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 294 Answers
With the cover off, there are little white gears down on the right bottom that activate a ink plug tray.
Lid-open sensor is a gray tab on the lid that interrupts a black optic sensor on the circuit board. If your printer gets wet and no power up, unplug printer and short the two capacitors on the smaller circuit board to clear internal printer fault memory. Insulate yourself, small voltage in there even unplugged.
Posted on Dec 08, 2010
Testimonial: "Never thanked you. Thank You!"
Our hp deskjet 932C printer is leaking ink. What
You could carefully clean this as follows:
put the printer on some newspaper to avoid further spills.
Turn on the printer, then open the lid to allow the carriage to move to the center.
Now unplug the printer, then gently move the carriage to the left and out of the way.
You should now have limited access to the spittoon area.
You can clean this area by carefully scooping out the ***** of ink with a plastic spoon. (Be careful not to drop ink sludge on your printer, desk, carpet or clothing.)
Once most of the ink has been removed then use a crumpled paper towel to soak up the ink in the bottom of the service station.
It may take several rounds of this to clean up the service station.
It is not necessary to completely clean the service station, just get the majority of the ink out.
Once this has been completed you could turn the printer up and clean the bottom area of the printer. Do not tip up the printer before the service station has been cleaned or you are likely to create a mess....
hp printer ink cartridge
May 09, 2010 | HP DeskJet 932c InkJet Printer
did you use genuine cartridges, if no, use genuine one
If yes, contact me at
walid_sayed@hotmail.com
Mar 16, 2010 | HP DeskJet 932c InkJet Printer
The left red light is flashing, but the printer has new ink. carson
Hi:
Often these printers are finiky when you remove and install the cartridges. If you are getting the red light, you need to remove both cartridges, re clean the contact strip on the back of the cartridges with a paper towel , dampened only with water, then make sure they are dry. Next, gently brush the contacts that are on the back side of where the ink cartridges mount. I use an old toothbrush. Remember the GENTLE part! Re assemble the ink cartridges in the printer, and hope for the best!
Nov 22, 2009 | HP DeskJet 932c InkJet Printer
Ink light won't go out
It was a problem with the black ink cartridge. I changed it and the printer is working fine.
Oct 05, 2009 | HP DeskJet 932c InkJet Printer
I thought I was out of black ink, so I replaced the #45 black ink cartridge in my DeskJet 932C printer and it still won't print in black ink.
check the printhead especially the black partition and see if the nostril on the printhead are not damage. does the ink lid blinking if yes clean or replaced the cartridge
Aug 30, 2009 | HP DeskJet 932c InkJet Printer
Where I put the ink cartridges is really over inked
Try soaking up as much as you can with a paper towel first then clean the remaining up with q-tips(swabs) use rubbing alcohol or some other form of Glycol to wipe away remaining mess.
Hope this helps FixYa,
Chris
Apr 20, 2009 | HP DeskJet 932c InkJet Printer
Paper Jam Issue with the HP Deskjet 5440
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
-levibit-
Mar 20, 2009 | HP Deskjet 5440 InkJet Photo Printer
Hp 932c ink leaking
The manual from HP explains how to clean print cartridges and more. Hope this has what you mean. If you're cleaning the rollers, use DENATURED (not rubbing) alcohol.
http://h10032.www1.hp.com/ctg/Manual/bpd07427.pdf
Mar 18, 2009 | HP DeskJet 932c InkJet Printer
HP deskjet 932C
If you hose it outside it will be a mess and will take an hour. A wet circuit board will need complete drying for a day and sometimes require to short out the capacitors to clear fault memory for power up.
Many little motors in there don't like to get wet.
Oct 27, 2008 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
134 people viewed this question
Ben Johnson
