Question about Brother DCP-7020 All-In-One Laser Printer
Ink cartrites are in and the machines say it is not
We have a wireless broters all in one printer, we disconnected it to move to another part of the home.
There is a message coming in saying there are no cartritges.
We removed them and re installed them and it still is coming up with the message.
    President:
  • 2,692 Answers
HP 4630 printer has error code oxc4eb827f
Welcome to the HP Support Forums!
I see that you're getting the error code: 0xc4eb827f on the front panel of your HP Officejet 4630 e-All-in-One Printer. I'd like to assist you today with resolving this error. The failure itself may be within the print system in your printer. Due to the error state there is only one support step that we can attempt, which is a Reset. Can you please follow the steps below.
Reset the Printer:
Without turning off the printer, disconnect the USB cable from the rear of the printer.
Remove the ink cartridges from the printer. *
Wait until a message to insert the ink cartridges displays. If you do not see a message within a few minutes, skip to step 4 to disconnect the power cord.
Disconnect the power cord from the rear of the printer.
Wait 60 seconds.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
Reinsert the ink cartridges, and then close any open doors on the printer.
If you receive a prompt to print a calibration page, do so.
If you disconnected the USB cable, reconnect it to the rear of the printer.
Try to print.
Copy to Hp support.. hope this will help
Jun 20, 2017 | HP Office Equipment & Supplies
My printer mx340 keep telling me error 5200 & not printing
Hello manful02,
Try this, With wour printer ON, DISCONNECT the power outlet open the printer cover to access the ink cartridge, pull the cartridge manually to the center of the carriage and pull out the ink cartridge, close everything and reconnect the printer, It will telle you that there are ink cartridge missing replace the cartridge, and it shoul clear your 5200 error
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 09, 2011 | Canon PIXMA MX340 Wireless Office...
My printer and computer have been working together fine on a wireless system. All of a sudden now my printer is not recognizing the print cartridges inside and wants me to remove the tape and install new...
Go to the store and buy some rubbing alcohol. Put some on a paper towel and rub the metal contacts on the back of the ink cartridges. If that does not work, also try cleaning the metal contacts on the inside of the printer with a paper towel and rubbing alcohol. If both solutions don't work, it is time to buy new ink cartridges or even a new printer.
Jul 29, 2011 | Lexmark X7675 Aio Wl USB Adf 32/27PPM Ocr...
My ink will not move to the side when I open the
Just make sure the printer is on when you lifted up the top cover for the ink cartridge holder to move to the right side.
You may also try this, try copying a blank paper, look inside the printer when you see the ink cartridges move in the side, disconnect immediately the power cord at the back of the printer. Now lift up the top cover and replace the ink cartridge.
Jul 07, 2010 | HP Officejet 4355 All-In-One InkJet...
I have a inspiron 1525 hooked wirelesly to my broter mfc490cw the comuter recognizes the printer and says ready and the printer is connected to the network but when i print it flashes recieving data and...
HI,
The following thing to be checked for not printing are as follows:
  • Check that the correct printer driver has been installed and chosen
  • Make sure that the machine is online. Click Start and then Printers and Faxes.Right-click and choose Brother MFC-465 ,and make sure that Use Printer Offline is unchecked
  • One or more ink cartridges can be emptied, so you dont get printed, check for that and if found replace the catridge
If all the above said is found correct, the drivers may be corrupted, uninstal the existing driver and reinatll it once again, it should solve your issue..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 31, 2009 | Brother MFC-465CN InkJet Printer
Moving a fax/copier/printer
NO...ink will spill out and corrode plastic parts.
Sep 27, 2009 | HP PJ9120 Fax, Copier, Printer, Scanner,...
Have code 44 on screen and printer does not work
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Brother MFC 4820c All-In-One InkJet...
Unable to Clean - Code46
it could be a faulty printhead, the broter printheads has a warranty of 3 years, log a call with a brother warranty repair centre
Apr 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Error message 6A00
AP position error [6A00] the Sheetfeed unit or the main logic board has failed need to purge unit. Give it a good tank cleaning, possibly replace cartridges. Is it still under warranty? Have you contacted Canon?
Jun 29, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Brother DCP-7020 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
