Question about Philips HDD1630 MP3 Player
Power i was charging my hdd 1630/05 and after this i cant to turn it off and reload,like pressing + and power button.
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
Where do i find manual for asus z92m ?
Remove the power supply, remove the battery, remove the RAM and remove the hdd.
Plug in the power supply and press the power button, it should complain as there is no RAM or hdd. Unplug the power supply, replace the hdd and RAM then power it up and press power on.
Jul 29, 2014 | ASUS Z92M Notebook
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif Spool Initialization
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif HDD Initialization
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif ESS NVM Initialization caution.gif CAUTION
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
My Dell Inspiron 1545 on Windows 7. After a system restore will not start. You switch on, The Dell logo appears, then the screen stays blank except for the cursor arrow which remains and can be moved...
Power drain your computer, remove all the accessories connected on it, including battery and power cord then press the power button for 1 minute.
Connect the power cord then turn on the computer.
This is a possible Operating system corruption and it needs a complete reloading of your operating system or reformat your HDD and install the OS again.
May 15, 2010 | Computers & Internet
My sansa screen went white
Try resetting the device by holding teh power switch in the ON position for about 15 seconds, then while it's OFF, slide the power switch DOWN to the HOLD position. Now for the tricky part, let's force a manual MSC connection. Press and hold the center button while plugging in to the USB port. Let us know if the screen lights, and the battery begins charging in this mode. If it's charging, let her charge for a while to give the battery a chance. Then, open a Windows Explorer window. I like to use [Windows key] + E, or go to My Computer. See if the Fuze appears under "devices with removable storage". If it's communicating, you have the options of formatting the device and reloading the firmware.
Jun 06, 2009 | SanDisk Sansa Fuze MP3 Player
Locked
Have you tried to remove the battery. If not, try this remove battery, see if that works. If removing battery doesn't work you may have to reset your player. First remove battery again, but before you put it back on, slide or hold your power on button, keep holding it down then insert battery. The load-up screen should come on asking to reboot, cleanup , or reload firmware. Just reboot and see what haps
Feb 01, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
X box console making clicking sound at start up, doesn't wrk
if this thing happens then that means your hdd is already corrupted.buy new hdd and replace it.that solves the problem
Dec 17, 2008 | Microsoft Xbox Console
Philips hdd 1620/05
Hold down the power and volume-up buttons for a few seconds.
Apr 03, 2007 | Philips HDD1630 MP3 Player
MP3 player not working
Connect your HDD/GoGear to the power supply with the AC/DC adapter, do a soft reset by pressing and holding the 051024111737_406.gif and the volume + keys at the same time for a couple of seconds, then switch on the Jukebox with the 051024111737_407.gif button normally.
Nov 02, 2006 | Philips HDD120 MP3 Player
Philips HDD1630 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
