I jsut bough the easy vac and it worked beautifully. I noticed the hose was clogged so I cleaned it and the canister. The vacuum is STILL not picking up and I've only used it once. HELP!
-   Has anyone gotten a solution to the bissell easy vac debris getting stuck in the hose instead of in the cannister? I made sure that everything is fitted on correctly, and as indicated by others it appears to be picking up but everything is just going into the hose or filter areas and not into the cannister.-   sydneyfl
Mar 10, 2009
-   Mine does the same thing. It seems like its picking up but nothing is in the canister after I'm done. It also seems to be blowing air out instead on in.
-   Guest
Jan 07, 2009
-   MINE IS THE SAME T HING! I need help too!-   karebear_620
Popular Solutions for Bissell 3102-0 EasyVac Upright
I have a bissell easyvac bagless. My son threw away my manual. I emptied it once and I can't get it...
(More)
I have a bissell easyvac bagless. My son threw away my manual. I emptied it once and I can't get it to work right again. I think it just needs to seel correctly, but I can't tell how to with out a manual. thank you Jeanel
I have a bissell bagless easy vac. When I vacuum the debris keeps getting stuck in the hose (also...
(More)
I have a bissell bagless easy vac. When I vacuum the debris keeps getting stuck in the hose (also going into the filter area and the apparatus above the cannister with none of it going into the cannister. I have made sure the cannister is properly placed and the lock is pushed in all the way.
