Question about HP DeskJet 3930 InkJet Printer
Scanning a word document Deskjet F4180
I am scanning a word document and would like to add it to an existing document. It does not ask me where the scanned document is supposed to go. I can push the copy button and it scans the document and then prints it but it will not scan it and hold it until I can add it to an existing document. What do I do?
  • 102 Answers
Scanning a document is the same as scanning a picture, it must be done from within the document app. In this case I'm assuming you are using Microsoft Word.
Scan a picture and insert it in a document@import url(/Office.css); To do this procedure, your device (a scanner or a digital camera) must be connected to your computer and be TWAIN-compatible. You should also make sure that you have installed the device software that supports TWAIN.
Some devices come with more than one software program. If you are not sure what software is TWAIN-compatible, check the device documentation or contact the manufacturer of the device.
  1. Set up the picture in the scanning device.
  2. On the Insert menu in Microsoft Word, point to Picture, and then click From Scanner or Camera.
  3. If you have more than one device connected to your computer, select the one you want to use under Device.
  4. Do one of the following: If you want to use a lower resolution or you intend for your document to be viewed on the screen, click Web Quality.
  5. If you want to use a higher resolution or you intend for your document to be printed, click Print Quality.
  6. Do one of the following: If you're using a scanner and you want to use predefined settings to scan your picture, click Insert.
    If you're using a scanner and you want to change image settings, or if you're using a camera, click Custom Insert. Then follow the instructions that come with the device you're using.
  7. When the image appears in the document, make any changes you want.
  8. You can use the tools on the Picture toolbar to make changes such as cropping the picture, and adjusting its brightness, contrast, and color.
Note The Insert button might be unavailable when using some scanners because the scanner software doesn't support an automatic scanning. Use the Custom Insert button instead.
Sub HelpPopup(sFile,sID) L_SecurityT1_ErrorMessage="Help can't show you this procedure because the security setting in your browser is set too high" L_SecurityT2_ErrorMessage="or the ActiveX control Ouactrl.ocx didn't install correctly." L_SecurityE1_ErrorMessage="- Select a lower security setting in your browser" L_SecurityE2_ErrorMessage="- If you receive this message after selecting a lower security setting, please see your system" L_SecurityE3_ErrorMessage=" administrator for help troubleshooting the installation of the ActiveX control Ouactrl.ocx" L_SecurityE4_ErrorMessage=" located in the folder you installed Microsoft Office to." sSecurityMSG=L_SecurityT1_ErrorMessage & chr(13) & L_SecurityT2_ErrorMessage & chr(13) & chr(13) & L_SecurityE1_ErrorMessage & chr(13) & L_SecurityE2_ErrorMessage & chr(13) & L_SecurityE3_ErrorMessage & chr(13) & L_SecurityE4_ErrorMessage L_App_DialogTitle="Microsoft Office Help" On Error Resume Next r=oua.HelpPopup(sFile,sID) If Err0 Then Msgbox sSecurityMSG,48,L_App_DialogTitle End Sub
Posted on Dec 20, 2008
How do i get my Hp Deskjet F4180 all in one printer to print double sided on a mac?
Hi,you can use this link..
h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00294482
Hope it helps...
Nov 03, 2010 | HP DeskJet F4180 Inkjet Color All-In-One...
I cannot scan anything
my officejet 5610 all in one ,,,does not scan ,,, message says refer to device documentation for troubleshooting,,, l lost the manual plz help
May 20, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
How do I scan using the HP Deskjet F4180 All-in-one?
open your upper door
place paper on glass
close the door
press scan
or install the software
from the software you can scan
Oct 29, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Cant scan on HP
Found this bit of instructions read it carefully and follow the step as listed
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05214&lc=en&dlc=en&cc=us&lang=en&product=3177566
Click on this link and it should help you Let me know how you come out though this website fixya.com biigg53566
Nov 12, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet F4180-no option to save as PDF
A simple solution to this problem is to scan to JPG as normal and then print the JPG to a PDF using one of the very good "print to PDF" utilities like the Cute PDF writer.
Good luck.
Aug 30, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Faxing
Phaio, I would like to inform you that the HP Deskjet F4180 did not have Fax feature it has only Print, Scan, and Copy
Jun 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet F4180 Scanning
ok..you may have blown drivers..go here, get new ones, and re install
Jun 16, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Instruction manual for hp f4180 printer
Here is the link for the manuals for your printer. Hope this helps http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=3177566&lang=en&
Sep 17, 2007 | Office Equipment & Supplies
HP DeskJet 3930 InkJet Printer Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
