Question about Pioneer VSX-516-K
Audio Tape not recording
There is no signal on the "rec" outputs for the tape. I tried two different signal sources: VCR and DVD. I tried the tape/MD record output and the VCR audio output. I tried two different Cassette Recorders. Any idea?
    President:
  • 3,130 Answers
There is a bad IC in the preamp stage of this amp and will require a signal tracer to troubleshoot to see where the signal is lost. Good Luck
Posted on Apr 03, 2007
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
How do I link my technics ge 70 graphic equaliser to my technics cd player sl-pd7a and my technics md player sj-md100 with phono rca leads . Thank you Simon
It would help to know what other electronics (receiver, maybe?) is involved.
If neither of those devices is a recorder, why do you need to connect them to the EQ when your receiver/preamp may have the facilities to connect the two playback devices directly; and the EQ in a Tape Loop?
Scenario A)
Assuming you REALLY want to have the CD and MD input through the EQ because you can't attach them any other way...
CD audio OUT to Line In; MD audio OUT to Playback;
EQ LINE OUT to whatever analog electronic inout you have in mind.
To hear and Equalize the CD set the Input Selector to Source, EQ REC button OFF; to hear the MD equalized set the Input Selector to Tape, EQ REC button OFF.
Scenario B:
You have a receiver with only ONE Line Level Aux input and a Tape Loop.
Insert the EQ in the Tape Loop. Attach one of the disc players to AUX and the other to the TAPE conenctions on the EQ.
Scenario C
You have a Home Theater System or Audio Vido Reciever.
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 01, 2011 | Technics Audio Players & Recorders
Trying to hook up my yamaha eq-70 to my new htr-5063
You don't. No tape loop or other place to insert it between the analog sources and the amps for the front channels.
http://www.retrevo.com/support/Yamaha-HTR-5063-Receivers-manual/id/23658bh532/t/2/
You'll notice on page 22 they don't show a return (playback path) from the 'audio recorder' or the VCR. That's a clue that there's no tape Rec/Playback loop, which is required for any external audio processor.
You can send analog audio out OR you can accept analog audio in, but you can't do both at the same time. Sorry.
Just the same, IF you had a Tape Loop or could break into a Pre-Out/Amp In slot...
Be advised that the engagement of any device in a Tape Monitor loop on most late-model Audio/Video Receivers (*) will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
* But not the HTR-5063.
Okay, back to the hook-up IF you had a Tape Loop:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Amp-, Rec-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Amp-, Play-Out.
Jan 27, 2011 | Yamaha EQ-70 Home Equalizer
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
How can I get audio and video out from my tv if it only has audio and video in.I'm trying to connect a dvd recorder to record programs off the tv but tv does'nt have output signal.
connect dvd input cable (three banana plugs red, white, and yellow) to the video and audio output on a vcr, then take a screw on cable from the Ant. to the vcr. you will have to tune the vcr to the programs channel to record the picture. The vcr manual should tell you where the signal will be going, The picture should also go to the tv on ch 3 or 4 as when you play a vcr tape.
saddikins
Aug 05, 2009 | Televison & Video
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Pioneer VSX-516-K Logo
80 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
