Question about Toshiba Satellite A65-S1062 Notebook
Have a toshiba satellite a65-s1062 power light is on but doesnt start up. I can hear fan on, I tried connecting it to my computer monitor but there is no picture. what's wrong?
Is there a way to restore factory settings (out of the box settings) for the Toshiba Satellite A65-S1062?
Hi blackrose696. There's 2 ways. 1.- If you go to My Computer and see a partition (probably D:) called recovery, go to Start - All Programs - and see if you see under Toshiba - something called recovery or restore (you WILL loose ALL your data) and follow the instruction. If you DO see the partition but you dont see anything under Toshiba folder, then restart the computer and inmediately you will see something like Press F10 or F12 to boot from recovery partition.
If you dont see the recovery partition. The only way is using the Restore CDs... if you dont have those you have to order them from the Toshiba website. (they cost like $15) so that way you are sure you get the license and the drivers correctly. I hope this helps. Please do not forget to rate and provide positive feedback from our support today. Thank you :D
Apr 30, 2010 | Toshiba Satellite A65-S1062 Notebook
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
Serious issue with a proc upgrade for my Toshiba A65-S1062
just because a chip is supported does not mean that it wont need a bios update.
Mar 09, 2009 | Toshiba Satellite A65-S1062 Notebook
Doesn't start up power light is on though? connected to my computer monitor and there is no picture?
Then it is safe to say that you have a hardware problem.  The laptop is not making it through the POST sequence (Power On Self Test).
Laptops are very difficult to work on internally - first, try to remove anything external.  USB drives, any add-on memory (not internal memory though), printer, anything at all.  Also remove the battery and plug the laptop into AC power.  Try to power on again and see if you get any response.  If you do, post back what happened and we'll go from there.
Dec 20, 2008 | Toshiba Satellite A65-S1062 Notebook
Satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 04, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A65-S1062 Notebook Logo
178 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
