Question about Maytag MSD2454G Side by Side Refrigerator
Msd2454grq in need of diagram for plumbing water/icemaker system
I recently bought a msd2454grq and someone had removed most of the lines for the icemaker and water dispenser in an attempt at eventually replacing them.. i have all the tools and hoses i need to make all the connections, but i do not know which valves control what, and which hose is in for the filter, etc. etc. any help would be greatly appreciated
  • sporkaliciou Dec 20, 2008
    my biggest point of confusion is that there are 2 solenoid valves both with 1 inlet and 2 outlets, could one of these have been added in as a replacement for the other?
  • smith 2008 Mar 25, 2009
    how do i determine which line is for incoming water source and which line goes to ice maker?
  • 700 Answers
Ok here's how it goes, first line from water goes to the filter then out of it to the solenoid vale, then it goes to either the icemaker or inside of the refrigerator to the resevour tank and the to the door.
Posted on Dec 20, 2008
My side by side refrigerator is making a buzzing noise from the ice maker area every few minutes
That sound you here is the icemaker calling for water to fill the icemaker but not water into refrig to fill icemaker. If you have no water connected to icemaker,lift up and lock arm into place to turn off icemaker,if you do have water line connected but no ice is being made need to see why water from house plumbing is not coming into the refrig.
Gene
Aug 11, 2011 | Frigidaire Refrigerators
Which water line or lines do I connect to refrigerator, model # ED22RFXW01, man. 08/99
It's advisable to go with flexible plastic tube with sweet water supply. Please follow the instrction as per video attached.
Even if your refrigerator comes withan automatic icemaker, you will need to connect it to a water supply for it tomake ice. While this is not a particularly difficult job it requires someknowledge of plumbing and the use of tools. ThingsYou'll Need:
  • Compression Nuts
  • Knife Or Scissors
  • T-valves
  • 1/4-inch Copper Or Plastic Tubes
  • Drill Bits
  • Variable-speed Drills
  • Drill Bits
Read theinstruction manual that came with your refrigerator. Specific instructions forhooking up the icemaker may be included. Locate thepipe nearest the icemaker that carries cold water. Most often, this is the coldwater pipe that connects to the kitchen sink. Install at-valve in the main cold water line - not on the 3/8-inch faucet tubes - sothat there are two outlets: one to the sink and one to the icemaker supplyline. Turn offthe water. Put asleeve and compression nut over the line that will supply the icemaker in orderto tightly connect it to the water line. Turn thewater back on, and, holding the end of the tubing in the sink or over a bucket,flush the line to remove any debris. Turn the water off again. Snake theline from the water source to the icemaker connection, drilling holes in thebacks of cabinets if you have to in order to push the line through. Find theicemaker inlet from the refrigerator and attach the other end of the line usinganother compression nut. Turn thewater back on. Throw awaythe first few containers of ice to be sure the line is completely clean beforeyou use the ice.
http://www.youtube.com/watch?v=vB-uUMsckSA&feature=related
thanks.
Feb 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water coming into ice maker
First, make sure your icemaker is on. if the switch has been acidentally flipped, that is why you have no water coming in. next see if the line is pinched behind the fridge.also check to see that a child or maybe someone cleaning didnt turn it off at the water supply line. if neither of these,check to see if you water supply is working. shut it off,remove the line, turn it on again with a glass or bowl underneath to be certain you have a water supply. if that is ok, check your water line again that goes to your icemaker, it may need replacing.
Jan 13, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side icemaker bin on door, 6mths old, water is only filling part of the ice maker and those cubes are not very large, also changed water filter in Nov and red light is on again to change...
Concur with the water valve solenoid; have had this experience several times with two way and even three way valves. Pull the unit and remove the mixing solenoid after the water is shut off. Sometimes a simple good cleaning and reassembly can make a difference but a replacement is the best answer. Your water dispersion is timed by the solenoid to fill the icemaker. Ergo, the water being dispensed at both ice AND drinking should flow at 1 ounce per second, optimally. The filter issue could indicate the presence of hard water debris already in the system and you'll need to trace that all the way back to the plumbing valve. If it's a needle tap, remove it and plumb in a good valve, I hate those things.
Jan 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have an older Frigidare and would like to hook up the icemaker. In the back bottom left side I THINK is where I would insert my water line but the line is so much smaller then the blue plug area. does...
The water supply line is a small 1/4" tubing (soft copper or milky-white plastic) and uses a compression fitting. That is normal. You can go to most any hardware store and get a kit for connecting the icemaker. The kit has the tubing with fittings, and a piercing saddle valve you install on a COLD water line to supply cold water to the unit. If plumbing is not your strong point, please seek help. Although it is pretty straight forward, it can be a little tricky.
Dec 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
How do I turn on the icemaker for my new used Kenmore coldspot Model # 106.56534400.
Hello. The icemaker needs to be plumbed into your cold water system to work and it also has an on off lever, usually a wire inside of the area where the ice cubes accummulate. Assumming that your fridge is plumbed already, just follow that little 1/4 inch line to where it is hooked into a larger pipe and you should see a small valve which also has to be turned on. Remember when turning a valve that right is tight and left is loose sooooooooooo turn it to the left [counter clockwise]. Regards, Joe
Dec 14, 2009 | Kitchen Ranges
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker does not work
Dec 15, 2008 | GE Profile PCF23NGW Side by Side...
Maytag MSD2454G Side by Side Refrigerator Logo
275 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
