T-Mobile Sidekick ID Cellular Phone Logo
delta Posted on Sep 23, 2017
T-Mobile Vairy Touch II, (Problems), when i select-tap a number on the screen numeric key board, the number below is displayed. eg. tap no 6, then no 9 is displayed, 2 gets 5 etc. If in icon mode, to select the (settings) icon, I have to tap the (www) icon above it. Tap any icon or number, the one below it is selected, same in menu mode. What's wrong ?
2 Related Answers
Anonymous
  • Posted on Aug 01, 2010
SOURCE: How do i put the battery in my vairy touch ii
On the top, at thethe right of the on/off switch there is a small opening, with you nails you can peel the backside a little bit off, and do this to the whole upperside of your mobile and after that you can insert your battery
Anonymous
  • Posted on Mar 25, 2011
SOURCE: T-Mobile Tap phone dropped. Touch screen not
Keyboard is not working for my t mobile phone
How do I master reset the phone lock code for my ZTE G N290?
Hard Reset: 1.Power OFF the handset. 2.Now press and hold the Volume Up, Muve Music key and the Power keys for 10 seconds. 3.A test screen (Triangle / Exclamation mark) will be displayed as below. 4.Press the Volume Up and Volume Down keys simultaneously to access the System Recovery screen. 5.Scroll using Volume and select "Wipe Data/Factory reset" and press the Muve key. 6.Scroll using Volume and select "Yes - delete all user" and press the Muve key. 7.When complete the system recovery screen is displayed. 8.Select "reboot system now" and press the Muve key. Master Reset: 1.Tap the Menu key 2.Tap Settings 3.Scroll to and tap Privacy 4.Tap Factory data reset 5.Read the message about erasing data 6.Tap Reset phone 7.Tap Erase everything.
Mar 30, 2014 • Cell Phones
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
T-Mobile Vairy Touch II, cant get my touch screen to calibrate properly. Icons, menu line or numbers not aligned up. I have to touch above icons or menu or numbers to select. It looks as if the selec
my vairy touch ll, always bad reception, the music isnt loud enough, the alarm has a mind of its own and most importantly the touchscreen plays up every so ofter, no matter how much times you take the battery out and try to clean it, it never works... I sugest giving that phone to charity or selling it to buy a new one but that's if anyones dumb enough to buy it off of you.
Hi i need an unlock code for my tmobile vairy touch 2 the IMEI NUMBER IS 357692032802145
You can get the Unlock code for your T-Mobile Vairy Touch II Phone at here
Superunlockcodes and get the free instructions from here
Mobileunlockguide and enter the code correctly...
Jul 09, 2011 • Cell Phones
2helpful
Can i download skype on my (t- mobile Vairy Touch 2) please reply as soon as you can.
Per this page Skype is not supported on your phone.
http://www.joy2day.com/mobile-world/t-mobiles/t-mobile-vairy-touch-ii.php
Here is Skype's website mobile support page with supported phones.
http://www.skype.com/intl/en-us/get-skype/on-your-computer/windows/
Good luck.
Apr 18, 2011 • Cell Phones
7helpful
2answers
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Completion
How do i unlock my T-Mobile Vairy Touch online for free?
You won't get a free unlock solution for the T-Mobile Vairy Touch, however unlock codes are inexpensive. I have posted a link to a site where you can get an unlock code for just £7.00 below.
Unlocks
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
6helpful
4answers
Servise mode
different models use different display methods, if there is any sort of touch screen it will appear there in an alpha-numeric display
eg U4-2 or J3-2 etc.others just display symbols if there is no touch screen (symbols like a pyramid of dots for out of toner, crossed circle for drum end of life etc) some of those will display a number if you hold down the clear button or the stop button, depending on the model
there are probably 5 or 6 different diagnostic systems needing different entry modes...you will have to be very specific with both the code and the model number of the machine
Top T-Mobile Cell Phones Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
