Question about 1995-1997 Yukon Ignition Starter Alarm Switch
1997 gmc yukon doesn't start when the engine is hot.
My yukon will start if the engine has been cold. as soon as turn off the engine and then retry to start it nothing happens. I sometimes have to keep jump starting the car
    Problem Solver:
  • 11 Answers
I have a 1995 gmc yukon and when the motor was cold she start with no problem and run greatr when the motor get to temp and you shut it off it would start i tryed clean contact on the starter and that didntr work i tryed the battry cables that didnt work i was told tht it may be the oil sending unit i changed that and the problem went a way not say that your problem but look at the oil gauge see what it is doing when starting and then take it from there good luck hope this helps .....................
Posted on Nov 23, 2009
    Problem Solver:
  • 8 Answers
Sounds lIke the contacts in the starter are expanding when hot. If you the vehicle should start when it is cold.
Posted on Dec 21, 2008
  • def1145 Dec 21, 2008
    Sorry, new to this sight! If the vehicle starts when cold you may need to change the starter of check the starter relay.
I replaced my water pump in my 1999 gmc yukon my check gauge light stayed on and temp gauge stayed over to hot side. can i reset it?
Not exactly.
The check gauge warning light is on because the temp gauge is reading hot.
Does the temp gauge read hot as soon as you turn the key switch on, or not until the engine as run for a few minutes ?
If it reads hot without the engine being started, there may be a short in the wiring or the sensor may have failed.
Apr 19, 2013 | 1999 GMC Yukon
1997 GMC Yukon runs great but starts hard
That's often a sign of a failing check valve in the fuel pump. Try this. When you turn the key to RUN, the fuel pump activates for 2-seconds to boost any lost pressure. Try turning the key to RUN, then OFF and repeat three times. If the engine starts right up, you probably need a new fuel pump. The real test is called a leakdown test where the shop throws a pressure gauge on it and leaves it overnight. If it loses more than 5-10-psi, the check valve is shot. Can't be replaced separately .
Oct 10, 2017 | 1997 GMC Yukon
A/C blows only hot air in 2004 GMC Yukon XL.
Is it properly charged? A check of the pressures would be a place to look next.
May 10, 2017 | 2004 GMC Yukon
2002 Yukon Hesitation when starting- No checking engine lights!!
This can be fuel pump related or just fuel filter related, spark plugs and injectors.
When engine is cold vaporization of gasoline is minimum. When fuel vapor is less than required and the fuel mixture is not ideal, ignition happens harder than it does under ideal running conditions of engine. When fuel pups is sweak, or filter is limiting, or fuel injectors are not injecting gasoline with improper pattern inside engine, or just becasue of corroded spark plugs, cold engine faces difficulties during first ignition.
PS: sometimes car starts and stalls.it fails to start once more. this can be a sign of broken crank position sensor. FYI.
Nov 18, 2011 | 2001 GMC Yukon Denali
97 Yukon sometimes won't start, cold or hot. Does
Check for "Ignition crank sensors" GMC's are well known for water on these sensors and eating them up causing "no start" Hope this helps
Jun 17, 2010 | 1995-1997 Yukon Ignition Starter Alarm...
Timing 97 yukon
distributor has to be installed correctly and then timing set with scan tool
Sep 19, 2009 | 1997 GMC Yukon
2005 yukon xl hard to start
HOW MANY MILES? Has there ever been any major mechanical work done?
Jan 24, 2009 | 2003 GMC Yukon
1997 Gmc Yukon wont start
when you say it wont start will the engine turn over?
if it wont turn over i think you should check your battery connections
if the engine turns over then you need to check your fuel pressure and spark and let me lknow
Jan 02, 2009 | 1997 GMC Yukon
2004 GMC Yukon Denali
My wife had same problem in 2005 yukon. Turn both temperture controls on dash all the way as warm as they will go, Wait about 1 or 2 mins and turn back to coolest setting. Cleared our problem right up. Do this with car running and air on.
Oct 02, 2008 | 2005 GMC Yukon Denali
1995-1997  Yukon Ignition Starter Alarm Switch Logo
512 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
