Question about HP Computers & Internet
Reset button just blinks won't turn on - HP Computers & Internet
  • 58 Answers
1.  It may be stuck in standby mode.  Try holding the power button in for a few minutes.  See if the light stops blinking.  If it does, try powering on again.
2. Unplug the power cord from the back of your computer for about a minute.  Plug it back in and turn on the PC.
3. If these steps do not correct the problem, test the power supply with a power supply tester, or swap it with another one.  If you do this, make sure you obtain a power supply that is rated with at least as much wattage as the one you're replacing.
This can also be an issue with other hardware components - but in the majority of the cases I see on a weekly basis, the above solutions fix the problem.
Posted on Dec 20, 2008
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
Bosch silenceplus 50dBA won't start
After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
Apr 12, 2012 | Dishwashers
Low on oil ,added oil monitor won t stop blinking is there a reset button disconnected battery still blinking
The hour meter displays the total operating
It will flash CHG OIL (Change Oil) at 50 hour
intervals. The flash duration is one hour
before and one hour after the interval. The
CHG OIL icon will come on and shut off
automatically. The hour meter can not be
manually reset.
Aug 09, 2011 | Husqvarna Zero Turn Mower Z5426
My tv won't stay on.I pressed reset and input at same blinks twice and that's it.
You have to press the menu button and the input buttons both in together and hold for 6 seconds then count the two digit blink code and let me know the blink sequence.
Jun 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
A Blinking Power light on a wrt-54g usually indicates that the firmware is corrupt. You can try to wipe the firmware by following the steps below:
unplug the router
using a paper clip or pin, press the reset button
plug the router back in while the reset button is still pressed down and hold it for 30 seconds.
once you let go of the reset button the router should go through a reset. if it still blinks try the process again.
if the issue still occurs then it may be bricked.
May 27, 2011 | Linksys Wireless-G WRT54G Router
I'm trying to recharge my headset but the green light remains on (I clicked on the botton on the headset piece but it won't turn off). When I try to turn it off, it beeps at me
try doing a system reset press the call control button and the volume mute button at the same time for 5 seconds. when the talk indicator light blinks release both buttons. press the call control button again and the talk indicator light will blink again briefly headset is back to normal then unplug the charger from the charging jack for 5 seconds and plug back in headset is reset. if that doesnt work then replace the battery in headset.
May 05, 2011 | Plantronics CS55 Wireless Headset
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Computers & Internet Logo
54 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
