Question about 1995-1997 Yukon Ignition Starter Alarm Switch
My 1997 gmc yukon won't start if the engine has been runnin for a while
    Problem Solver:
  • 10 Answers
I know this problem. First, if you have not replaced the starter and solonoid within the last 150,000 miles then now is the time. That will solve your problem. But if your like me and your a cheapskate then this is what you do. Go to autoparts store and get a set of brushes for your starter motor, $5.00. Pull the starter and disassembly the motor, replace the brushes, etc. Disassemble the solonoid and inspect the points of contact where electrical continuity is essential. Remember 12 volt starter power is always hot at the starter. When you turn the key your just powering the solonoid coil which pulls the starter gear to the flywheel. This process also completes the circuit to the starter motor. When your car is hot, the expansion due to change in temperature will cause loss in continuity within the solonoid if parts are significant worn. Hope this helps
Posted on Jul 24, 2009
1997 GMC Yukon runs great but starts hard
That's often a sign of a failing check valve in the fuel pump. Try this. When you turn the key to RUN, the fuel pump activates for 2-seconds to boost any lost pressure. Try turning the key to RUN, then OFF and repeat three times. If the engine starts right up, you probably need a new fuel pump. The real test is called a leakdown test where the shop throws a pressure gauge on it and leaves it overnight. If it loses more than 5-10-psi, the check valve is shot. Can't be replaced separately .
Oct 10, 2017 | 1997 GMC Yukon
1997 gmc yukon backfiring and running rough
need to check engine compression, possible you have a burnt valve, also double check your firing order on plug wires on dist. cap
Sep 03, 2012 | 1997 GMC Yukon
I have a 1997 gmc Yukon that won't start...I just
It might be the cam or crank shaft senser.They do act like that when going bad
Dec 14, 2011 | GMC Yukon Cars & Trucks
1997 GMC Yukon won't start.
WHEN YOU REPLACED THE FP DID YOU OR THE DEALIERSHIP REPLACE THE FUEL FILTER MAYBE YOUR PROBLEM ....
Nov 12, 2009 | 2001 GMC Yukon XL
What is the spark plug placemnt for a 1997 GMC Yukon?
From the front of the engine: drivers side 1,3,5,7 Passenger side 2,4,6,8.
Jul 04, 2009 | 1997 GMC Yukon
Engine will not fire
is the spark blue?xheck all the connectors to the mfi iac and ignition module,and the distributor
May 28, 2009 | 1997 GMC Yukon
Rear axle seal leaking on 1997 GMC Yukon 4x4
You are Talking about the Main Cover on the Rear of the Rear end Correct???? If so, This is Just a Gasket and is Very easy to replace. The Gasket is Simply Worn out.
Jan 17, 2009 | 1997 GMC Yukon
1997 Gmc Yukon wont start
when you say it wont start will the engine turn over?
if it wont turn over i think you should check your battery connections
if the engine turns over then you need to check your fuel pressure and spark and let me lknow
Jan 02, 2009 | 1997 GMC Yukon
1997 gmc yukon doesn't start when the engine is hot.
i have a 1995 gmc yukon and when the motor was cold she start with no problem and run greatr when the motor get to temp and you shut it off it would start i tryed clean contact on the starter and that didntr work i tryed the battry cables that didnt work i was told tht it may be the oil sending unit i changed that and the problem went a way not say that your problem but look at the oil gauge see what it is doing when starting and then take it from there good luck hope this helps .....................
Dec 20, 2008 | 1995-1997 Yukon Ignition Starter Alarm...
1997 gmc yukon engine noise
it could be your oil pump or it threw a rod
Nov 08, 2008 | 1997 GMC Yukon
1995-1997  Yukon Ignition Starter Alarm Switch Logo
462 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
