Question about Whirlpool AWM6120 Front Load Washer
Changing Bearings Hiya, My washing machine makes a rumbling noise on spin and I self-diagnosed the bearings, I bought a bearings kit and now want to fit it myself, I have tools and some electrical/DIY know how and don't want to pay the £75.00 call out charge for an expert and so I'm surfing the net for any instructions or tips to enable me to do this properly and not mess up the machine completely, can anyone help?? Thanks very much - Shellsbells
  • Shelley Graveling
    Shelley Graveling Apr 03, 2007
    Hiya,
    I have already tried this - thanks for the tip though! Cheers Shellsbells
  • rics Dec 18, 2007
    have same problem , but not tried to fix it yet. looking for advice. or where i ca nget a repair manual.
    Problem Solver:
  • 14 Answers
The good news.for a service engineer this can be done quickly and easily.the bad news ..no service engineer worth his salt would change just the bearings on this model..best bet is to buy the whole back 1/2 tub containing the bearings.for more info contact me on dazzie@blueyonder.co.uk
Posted on Dec 30, 2007
Before starting with the your repair just try adjusting the washing machine's leg or reduce the load.
Posted on Apr 03, 2007
Noisy spinning
First make sure that the load is balanced, if you are washing and spinning a dense load like trainers etc this can cause an imbalance. If you are washing a duvet cover or a pillowcase, make sure that the loose clothes washed with it haven't migrated inside the cover or case, this happens so easily. It is always worth checking that the support feet are all touching the ground when the washing machine is empty as this can cause excessive noise
hope this helpsKind regards ki
May 11, 2015 | Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 22, 2014 | Washing Machines
Why does my washing machine make a load noise on the last 6 minutes of the spin cycle..especially when I have bed linens in.
It is not unusual for a machine to make a lot of noise and jump about when washing sheets as they can sit out of ballance in the drum. That is why the drum turns to and fro and short spins trying to balance the wash. If how ever the noise is rumbling like a big lorry going by, then I'm afraid it sounds like your drum bearings have gone. Replace bearings by an engineer or replace machine either is expensive.
Oct 01, 2014 | Samsung Washing Machines
When on spin,the drum is rattling and making a lot of noise
More than likely the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough, or is rumbling or grating, then the bearings have failed.
Dec 03, 2010 | Hotpoint WMA58 Front Load Washer
Washer makes thumping noise when spinning and belt jumps off
I suspect that the main drum bearings have failed.
Remove the belt, and from the front spin drum by hand, if it feels rough or is rumbling or noisy, then drum bearings have failed.
Can be expensive!!!!
Feb 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
LG washing machine repair
hiya
is it a rumbling noise? if so it may be the drum bearings are in need of replacing. two tell tale signs are
1, check clothes for any black speckles, as this is a clear indication that the bearing seal is worn and that oil and grease from the bearings are entering the wash tub.
2, whilst the drum is empty see if there is any movement in the drum, the easiest way is to place four fingers inside the lip of the drum and place your thumb on the door seal and pull it towards you in an up and down motion. if there is any movement then the bearings need replaced.
hope this helps
Jul 31, 2008 | Washing Machines
Noise
yep! your right drum bearings or transmission !!I would go for drum bearings ,not easy!!
Dec 19, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool AWM6120 Front Load Washer Logo
170 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
