Question about Konica Minolta magicolor 2430 DL Laser Printer
How to print addresses on envelope
How do I print envelopes on my Konica Minolta 2430 DL color laser printer?
  • Debbie Dauray-May Jan 20, 2009
    I have the same quesiton. Please let me know if you figure it out.
    Debbie
  • 214 Answers
SOURCE: printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Posted on Jun 19, 2008
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
  • 12 Answers
SOURCE: Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Posted on Aug 05, 2008
frcs68
  • 1605 Answers
SOURCE: Will the Konica Minolta 2430 DL laser printor work with Vista?
here is link that you can see what other peopel are doing with this printer regarding WIndows Vista. it also contain a link for driver download.
I don't how good is the driver. but I believe there is workaround.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=962&filetypeid=4&osid=17
Posted on Oct 31, 2008
SOURCE: White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Posted on May 02, 2009
Paper won't feed on this printer. usually, after the first page prints, i have no more problem. it's getting the first one to print is the problem. Envelopes are tricky also.
Clutch for paper feed system might be dirty and require cleaning, will be hard to get to. You do have a legacy machine from Minolta.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 18, 2014 | Konica Minolta magicolor 2430 DL Laser...
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My printer is printing a duplicate image along with the regular print and also the print is light in color and smears. Konica Minolta magicolor 2430 DL, any ideas on what I need to do. The residence is...
The most common issues for duplicate image is either
the drum or fuser. If you are able to measure the distance between the first line and its duplicate, i might be able to narrow it down.
thanks
Jun 02, 2010 | Konica Minolta magicolor 2430 DL Laser...
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
Need small plastic piece for Konica Minolta Magicolor 2430dl
The part is probably one of the envelope levers. This is part of the Fusing unit which comes as a complete assembly. Individual parts are not normally available separately.
Apr 03, 2009 | Konica Minolta magicolor 2430 DL Laser...
When I print enveloppes with my Konica 2430DL, I get shadows, but not on other print jobs
When you look at an envelope, it has spots where there are 2 to 4 thickness of paper in spots.( folds of the envelope) If this is where your shadows are, and your printer does not have any settings for envelopes, your printer may not be able to print those types of envelpes. You might try a lighter and thiner envelope.
Mar 03, 2009 | Konica Minolta magicolor 2430 DL Laser...
Printing envelopes
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica minolta magiccolor 2430 dl
Under Quality Tab you have the option for B/W printing.
Nov 29, 2007 | Konica Minolta magicolor 2430 DL Laser...
Image quality
Make sure the paper isn't set for "envelope width"
Oct 13, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
