Question about Kenmore 24032\24036 Top Load Washer
Doesnt spin MY EASHE MACHINE DOESNT SPIN UNLES I MESS WITH SWITCH
  • Phil Brantley
    Phil Brantley May 11, 2010
    What switch effects it , the timer or lid?
  • 640 Answers
Booth from timer to lid,,if you giggling with either its time to replace that part..happy new year,,ps if you need me to walk you through im here,,replacement
Posted on Dec 31, 2008
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 28, 2010 | Roper RAS8445KQ Top Load Washer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My washer doesnt wanna spin
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jul 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
