Question about HP DeskJet 842c InkJet Printer
Amber light blinking. Do both cartridges have to be installed
I took out the color and the black cartridges, but only relaced the black. Do both have to be installed in order to work.
  • ljennings199 Dec 22, 2008
    I trashed the color cartridge
    I don't have it any longer. I only have the one black cartridge. My question is if it will work with only one cartrdge???
  • Anonymous Feb 07, 2009
    we have only the color cartridge installed in our hp deskjet 842c. The amber light keeps flashing, but nothing works. Any ideas? We'd like to test, but that doesn't work either.
    President:
  • 1,179 Answers
You can replace the cartidge that is empty without replacing the other. Hope this helps.
Posted on Dec 20, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 22, 2008
    It should work but you will no longer be able to print in color.
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
Orange blinking light at cartridge icon
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Sep 10, 2009 | HP DeskJet 960c InkJet Printer
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
There 3 light on the printer that able to indicate to user when problem occur.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Amber light!
Clean the contacts in the cartridge holder (Iso alcohol & cotton swab work well).
Dec 23, 2008 | HP DeskJet 920c InkJet Printer
I've just installed my HP deskjet 920c printer, but the amber light seems to not stop blinking. I've installed only the black ink (c6615d) 'cause I have no use for the color ink.
You can't operate the printer without the color cartridge, even if you don't need it. You can always keep an empty one in, but you must have both in.
HP DeskJet 842c InkJet Printer Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
