Question about Xerox Phaser 7400/DXF Laser Printer
PRINTER ERROR Xerox Phaser 7400 /DXF Laser Error 940
  • Anonymous Dec 20, 2007
    keep getting report fault error 940 every couple of months
  • bkrenning Jul 09, 2008
    Users complain printer will grind but still prints then displays a 940 error. The service manual indicates a 940 error is related to the waste toner auger, motor and/or sensors. Toner appears to backup in tubing causing cyan chute to overflow. I've cleaned up the toner, manually emptied the waste toner reservoir & manually rotated the waste toner auger motor. Printer will work fine for a day or two then again displays the 940 error. I'm going to try replacing the waste toner auger motor even though it appears to function normally.
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
    Novelist:
  • Xerox Expert
  • 297 Answers
The grinding noise is caused by a worn or bad gear in the drum unit.
(if you are refilling the toner cartridges you may be overfilling, causing the gears to grind).
Also make sure the Imaging Unit basket is properly latched, some machines have a tendency to work loose over time.
SOURCE:
Where is the waset container located in the phaser 7400? not my machine
As far as I know it's under the cleaner assembly, usually with an orange handle on. Should pull out.
Good luck.
Jun 09, 2014 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
Feb 24, 2012 | Xerox Phaser 7400/DXF Laser Printer
Xerox 7400 wont print colour
Did you load up the "Universal Printing Driver"??? it only prints monochrome on most Xerox printers...
You should use the PostScript Driver for this printer.
Dec 02, 2011 | Xerox Phaser 7400/DXF Laser Printer
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
Getter "Report fault 917" on my Phaser 7400. How can I fix?
I am getting a report fault 917 error on the phaser 7400
Sep 23, 2010 | Xerox Phaser 7400/DXF Laser Printer
Phaser 8560DN display Panel is blank
I got support from xerox. I need to get a replacement display panel for my printer. www.support.xerox.com
Oct 22, 2009 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
1,802 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
