Question about Panasonic Viera TH-50PZ80U Plasma TV
No picture via HDMI cable
Panasonic TH-50PZ80U TV is 2 months old and picture output is through an HDMI cable from a satellite cable box. Everything was fine then all of a sudden the TV displays a "SHUTDOWN IN 3 MINUTES" message. Since then I can't get a picture through the HDMI cable but I can through component cables. I have 2 HD satellite cable boxes and neither will ouput a picture via HDMI to this TV. I've swapped HDMI cables to ensure the HDMI cable wasn't bad and still no picture.
  • Anonymous Dec 31, 2008
    I have the same problem. I just took my tv off the wall to hook up a Wii & when I reconnected the HDMI inputs don't provide a picture, but all the component video work fine.
    Does anyone have a clue?
  • bdh0624 Jan 02, 2009
    Same issue for me with a TH-50PV80H. The problem started when I connected a PC via a HDMI cable to the TV. Now I just get a black screen - no picture or sound.
    Occassionally, the PlayStation - connected via a HDMI cable will work - but only for a hour or so and then I'm back to a black screen for all the components.
    Connecting the PC via the the VGA cable works (but the picture is not as good), same as the RCA jacks ... but then what's the point in having a HDTV.
    I received a post last night indicating that it was likely a faulty signal card.
    Good luck - I'm going to take mine in for service (and live without a TV for the next 3 weeks).
  • 39 Answers
SOURCE: Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Posted on Dec 17, 2007
SOURCE: Panasonic Viera TH-50PZ80U No sound no audio only buzz.
Found the screen had a small crack and was shorting the video circuit.
Posted on Jan 09, 2009
SOURCE: Volume Problems: Panasonic TH-42PZ700U
please could you send me tips of what the problem of my plasma keeping stuck pixiel panorama LCD Tv model 42LC68T
Posted on Mar 31, 2009
marketex
  • 371 Answers
SOURCE: TH-42PX60U All output ports works but HDMI ports
Problem is with your ISP/Cable Company accepting the installation as one with HD clients, which while
not necessarily costing you more, must be specified to the cable box by your installer.
Make the call.
Posted on Apr 17, 2009
Grubhead
  • 5342 Answers
SOURCE: Thunder storm came thru...my th-50pz80u HDMI ports
I think you would be better having the set to repair shop. It might be not just those ports that has been affected. Modern devices are full of static sensitive parts and lighting is a bit more powerfull than mere static. It could also have comprimised safety features, to prevent fire; for instance. I would take it to a Pansonic service center to be fixed to be on the safe side.
Posted on Aug 11, 2009
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Dec 07, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
My plasma TV is not getting a signal from the hdmi cables. They worked earlier today and I have not changed them. The game system is the only component functioning now.
Tries tv unplug,replug it back like about hour later.For the tv do a resetting itself,take out the tv HDMI cable out the old HDMI hub port try plug it into another tv HDMI hub port.Should work now,still have same problems,probally needed a new HDMI cable replacement,the old HDMI cable is worn out or shorted out.
May 08, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Tv will not turn on. Flashes 10 times. If we unplug/plug it basck in several times we can eventualy get it to work. Seems to be getting worse every day.
You need to replace the power supply, PN: ETX2MM704MGH. This 10 flash failure is common. I hope this was helpful, best wishes.
May 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Cc box
Open the menu, then go to setup, there should be a closed caption options in there, also remember that CC can only be passed via a transmitted cable signal. If you have a Cable box or Satellite box connected via HDMI, or its pushing a HD signal (720p, 480p) the CC box is from the Sat or Cable box, test the settings on the box.
Sep 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Killed by lightning, have power, no picture...
The warranty does not cover lightning, check if your insurance covers it.
A lightning strike on such panel ( HDMI ) is very difficult to repair and if not impossible.The HDMI connector is hooked to the ground of the TV set so everything could be damaged.
My advice is not to repair.
Aug 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Just bought a 50 panasonic viera, when we hook up ps3 on hdmi cable, we have sound but no picture.
Plasma TV normally do not have the resolution required for PS3 unless the plasma TV is fullHD( 1920x1080p) pixels.
HD Ready Plasma = 1024 x 768p
PS3 Outputs = (fullHD)1920x1080 or (HDReady) 1280 x 720p.
LCD TV accepts the resolution matches the resolution the PS3 is outputting.
Feb 28, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic th-50pz80 10 flashing blinking red lights
The way to solve the problem with the TH-50PZ80U blinking light problem is to not buy Panasonic Products. I have had my TV about 21 months and it has started with the blinking light problem, just out of warranty. Panasonic is aware of this problem and refuses to do recall or fix the tv unless you are within the warranty or have bought the extended warranty. Legally they are within their rights, but I am also within my rights to air my complaint and inform others of this below par product. Who wants a TV that they have to unplug for a while and pug it in again for it to work. I want to push the power button and it come's on. I will never purchase another PANASONIC PRODUCT.
Jan 03, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera hd tv th 50pz80u
I have the same model and have the same problem. I have an Onkyo receiver that connections to the TV via HDMI cables. If I turn the TV power on first and then the receiver I don't get the blinks.
Dec 14, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera TH-50PZ80U Plasma TV Logo
205 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
