My fan (loud) comes on and runs for a few minutes every 30 seconds to a minute. I have cleaned it and am only running on like 3-6% memory. My physical memory is at 65%
GIF's and certain media and even Flash will make your Fan run continuously. Observe what you are doing when you hear the fan run. Also you said you cleaned the fan, did you open the bottom plate and then clean it? Also, is there a hard surface you are keeping the laptop on or are you sitting in bed using the laptop?
SOURCE: HP Desktop power up problem
Bad ram probably, units do that all the time at my job. Most of the time, it is the power supply that does not have enough power to invest into all hardware that makes your pc. even if you had a 400watts power supply, the next time you are buying a power supply you should do some kind of upgrade. 600 watts or more. If you have a high end graphics card then you are indeed in need of a new power supply. also check your cpu, its fan, check if it still seated properly, if there still paste on top of it to hel cooling it down, and protect it from statics. if you added new hardware, remove them and keep checking if it is working. To do manual diags, you need to take the unit apart. I would start by removing rams first, and check ram one by one, then hdd, then disconnect other components until i find the actual part. I am sure it is your powersupply, worst case scenario is you mobo is gone.(but it powers up and shutdown after all so let us hope you don't have a dead motherboard." and remove the dust please, dusty units do not run properly. Neim Le Legionaire.
SOURCE: Fan runs loud,constant on HP a1620n
cheek the cable of cable properly plug in
R
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
R
cheek out fan for electric shot
repaly me if i solve your problem
SOURCE: the fan in my tower sometimes runs loudly and for a long time
May need to be cleaned if that doesnt work
Replace the fan it sounds like its getting old
SOURCE: My HP pavilion 533w only tries to turn on when the
Open the desktop, and re-seat the memory. Let me know if that works.
SOURCE: Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
