Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Hard drive not recognizing external device
I plugged in device and the red light came on and an icon appeared to click to start. I clicked on and got a blank window. Thought I did something wrong and closed the window thinking I could start from the beginning. Now my hard drive is not recognizing the external device. What do I do?
    Problem Solver:
  • 7 Answers
You may have to search thru add and remove for the device and remove it and then reload the device it may have only parshlely installed
Posted on Dec 20, 2008
External drive does not appear on the desktop. I have had this hardrive for about a year and a half and it is about at half capacity. When I plug in the USB to the computer the light on the device comes on...
Iomega portable hard drives connect to your computer through a USB port.
When you connect the Iomega hard drive to your computer, it should pop up as an icon in your
My Computer folder.
If you can't find the icon in your My Computer folder then you probably need to update the driver for the device.
Updating this driver is not very hard and can be done automatically from the Windows Device Manager.
Plug your Iomega hard drive into one of your computer's USB port.
Click the "Start" button and go to the "Run" field.
Type "Devmgmt.msc" into the Run box and press the "Enter" key.
Go down to the bottom of the device manager to the "Universal Serial Bus Controller."
Click on the little + (plus) sign to expand it.
Look for an entry with a yellow exclamation point and click on it.
Click the "Install the software automatically (Recommended)" button and then click the "Next" button.
Click the "Finish" button when the installation has finished.
Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon.
Double click the icon to gain access to the external hard drive.
Sep 08, 2013 | Iomega Silver Series 320GB 3.5 External -...
External hard drive cant format into ntfs but only exfat
The propriety NTFS file format is used by the Windows operating system to format internal as well as external hard drives. You can format an external hard drive with the NTFS format using the built-in program included with the Windows operating system. The procedure is straightforward and does not require any additional software. An NTFS-formatted external hard drive can then be used with any PC running a version of Windows that is later than Windows 3.
Plug the cable attached to the external hard drive into a USB port on the PC. Right-click on the "My Computer" icon on the desktop. Select "Manage" from the drop-down menu. Click on "Device Manager" in the left column of the window that appears. Click on the "+" icon next to "Disk drives" that is in the column to the right of "Device Manager." Right-click on the icon of the external hard drive. Select "Properties" from the pop-up window. Click the "Polices" tab at the top of the window that has replaced the pop-up window. Click the "Optimize for performance" button below "Policies." Click "OK" to close the window. Right-click on the icon of the external hard drive in the center column of the window that is still open. Select "Format" from the pop-up menu. Select "NTFS from the "File system" drop-down menu in the new window that appears. Click the "Start" button at the bottom of the window. Wait as a progress bar appears at the bottom of the window and fills in from left to right. Click the red "X" at the right corner of the window once the progress bar has completely filled in. format usb memory stick to ntfs http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Overview and history of ntfs format http://www.pcguide.com/ref/hdd/file/ntfs/over-c.html
Apr 02, 2013 | Maxtor OneTouch III Mini Edition 120GB...
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
A blue and red flashing light and won't connect to computer
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
Rocstor icon disappears from desktop and light is half orange/green
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
WD 320G external drive-- power lights on but drive did not spin and or appear in the icon bar. Not able to access the drive. Tried unplugging and plugging back in several times--does not seem to work....
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps you
Oct 30, 2011 | Computers & Internet
Hi , I'm having problem with my WD 500 GB external hard drive.My laptop and computer can't recognize the drive icon anymore and no usb connection icon is recognized by windows task bar.I have tried...
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps you
Sep 01, 2011 | Western Digital Computers & Internet
SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Aug 12, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
99 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
