JVC XV-THV70 sound goes off on when switching from DVD to TV.
After watching a DVD and switching from DVD to Aux the unit displays No Disc and the sound goes off for the TV. If you press AUX on the remote, the sound comes on only to go off again in several seconds. Repeated pressing of the AUX button will eventually restore sound to the TV. Also, disc door seems to hang open a little when this occurs. Sometimes pushing the door solves the problem.
SOURCE: Can't get sound from the wireless subwoofer
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
SOURCE: jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
Posted on Mar 09, 2008
SOURCE: JVC XV-THA5R multi-region DVD player - fault recognising a disc in and playing
I too have this same problem on my current DVD player, AND strangely enough I had the same problem on my previous player.
Previous player was made multi region and was a Sony S660 (I think that was the model number).
My current DVD player is a Denon and was £550! It is also made multi region and has the same problems! I don't get it!
Posted on Apr 23, 2008
  • 8 Answers
SOURCE: dvd is locked into machine,how do i unlock it?
Hi Hope this will help on the main machine while in standby press the eject button with the stop button press and held ,try that
Posted on Nov 29, 2008
dj x
  • 61 Answers
SOURCE: put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
Posted on Mar 05, 2009
Lock
The disc lock function has been activated on your JVC XV-N320, when in this mode the tray cannot be opened or closed.
If you press the 'eject' button whilst pressing down the 'stop' button on the machine in standby mode the disc lock will deactivate. To turn it back on you follow the same procedure. This is also described in the user manual for this model of TV umder trouble shooting on page 13.
Hope this helps,
James
Apr 23, 2010 | JVC XV-N320 DVD Player
''Bad disc'' error when any disc loaded in JVC XV-N670B DVD Player
There may be a connection to the problem, but it sounds like the laser assembly may need to be replaced as well as/or the mpeg printed circuit board(the printed circuit board) attatched to the laser assy. Good Luck.
Sep 26, 2009 | JVC XV-N320 DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
JVC - XV-F80 DVD Player
Either the disc or the player likely need a good cleaning. Clean the disc with a soft cloth, clean the player with a good cleaner disc.
Feb 26, 2009 | JVC XV-F80 Multi-disc DVD Player
Does not play any disc
Thats bad..Did you try another disc? If this happens even with a different disc. You will need to get a lens cleaner(costs about 5$) and try cleaning the lens. If it still doesn't work then you will have to replace the lens. The reason why it died suddenly is probably because the lens circuitry somehow got shorted. Try cleaning and if not.. replace.
Nov 14, 2008 | JVC XV-N212S DVD Player
Software problem with JVC XV N322
Reflash ur dvd player flash ic
Jul 21, 2008 | JVC XV-N320 DVD Player
Displays lock when trying to insert a disc
you need to find the unlock code for it. check the web site for the model number that you have and look for the unlock code
Jul 13, 2008 | JVC XV-S302 DVD Player
Jvc xv-s332 dvd player won't play
Jan 25, 2008 | JVC XV-N322
166 people viewed this question
 Grubhead
Grubhead
