Question about Acer TravelMate 2300 Notebook
I need to reset my computer
Once before I've run into this problem and it was just set back to how it was running before. Im not sure how to get to that setting and reset it to a day before it messed up. can you help???
    President:
  • 1,179 Answers
If you are using Windows XP or Vista you can use the System Restore option found under Start Menu> Accessories>System Tools> System Restore
Posted on Dec 20, 2008
1972 olds 98 455ci starts and runs fine when its cold but once i've driven it for awhile it starts sputtering like its running out of gas
sounds like a vapor lock. older cars needed a set of points . they kept firing times in sync with fuel delivery , valves opening/closing try that.
Jul 29, 2012 | 1972 Oldsmobile 98
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 | Watches
Im using a behringer ucg102 guitar/usb interface, im getting a very bad hum/hiss.. i've tried 3 different guitars and multiple jacks. im not running any guitar effects yet, i've removed the...
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
Jul 23, 2011 | Behringer energyXT2.5 Plus Portable...
When I try to installate the router on my computer, it asks for a pincode. That pincode is on my router, but when I enter it it says: wrong code.
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Jul 19, 2011 | D-Link DIR-600 Router
I will start the game, but the game says "you do not meet the minimum system requirements". But my computer meets the minimum requirements. I have played this game also in the past, but removed...
try running the game in compatibility mode. To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
For more information check out http://www.sevenforums.com/tutorials/316-compatibility-mode.html
Jun 20, 2011 | Global Star Software Airport Tycoon 2 for...
My son was set up and running but this morning he tried to go online and it told him he was signed off although the internet connection is enabled any ideas please
I would try resetting your router and seeing if the problem persists.
The problem also could be malware. Malware can get into your system and do some pretty harmful stuff. I would recommend both these 2 antivirus programs.
Malwarebytes and Avast Antivirus. These programs are both free.
After you've done a virus scan and the problem is still continuing to happen. There's only one thing you can do. Reinstall. Make sure all infected Items are removed. If you've got a USB or anything that's got infected items on it, and once you reinstall your pc, and put the infected USB back into the computer, Your going to have to reinstall again. so if you scan for viruses remove them. The computer should work again :)
I hope this helped jumboy124 :)
Apr 21, 2011 | Computers & Internet
Evap Sys Monitor
if evap is the only monitor that hasn't set yet, the car should still pass, a car is allowed to have 1 monitor that isn't set and still pass as long as the check engine light isn't on. take it in for the emissions, it should pass.
Jul 04, 2009 | 1997 Chevrolet Malibu
I am looking for my wirless routers web key Im not sure where to look people sa I should look for the Admin Page but im computer dumb haha please help!
1. connect to router using cable (RJ45)
2. make sure NIC configuration is set to dhcp client
3. click start run and type cmd in text field press enter on keyboard
4. type ipconfig /all in black window and press enter on keyboard
5. write down ip address of Gateway should be somthing like 192.168.x.x where x = number between 1 and 254.
6 open browser type in address bar http://192.168.x.x/
7 if you are promted for a username and password check the default username and password on the internet for the make and model for the router if this does not work then reset the router by finding the reset button usualy at the back of the router and use a paper clip to depress the reset button for at least 5 seconds go back to step 1.
8 once connected to web interface on router look for wirless LAN, security you will then find the network key or passphrase depending on what type of security is being used.
Apr 15, 2009 | Computers & Internet
Router model #
Better to reset the router by pressing the reset button for 30 seconds and then run again the setup CD of the router to reconfigure it back so you will know all the settings on it....
Aug 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
