Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I plug in reddy heater and flip the switch on and nothing happens
HH flashes on and off at the temp. indicator and fan only bumps on for an instant nothing else happens
    Problem Solver:
  • 6 Answers
The HH indicates that the control believes that the temperature is over 99. This happens when a) it is over 99 degrees (not likely or you would not be using the heater), or b) the thermistor is not plugged in or bad.
a) unplug your heater
b) remove the control cover (two screws where the display and knob are)
c) find the thin black wires with a green connector on the end. The other end of the wire are attached to the thermistor which looks like a balistic missile.
d) plug the green connector onto the white two pin connector on the circuit board. This is the only place that it will fit.
That should solve the problem.
Posted on Jan 07, 2009
Laars pool heater wont start.
check safety circuit starting with pressure switch if voltage on both sides ok if not check pressure switch if ok check copper tubing it gets clogged at header
Mar 27, 2013 | Jandy Laars Lt 400,000 Btu Heater
I recently switched out an anolog thermostat for a programmable one. I programmed it and everything looks fine except the furnace isn't turning on. I manually bumped up the temp and nothing happ
My suggestion is you made a wiring error. Does the furnace come on when you turn the thermostat DOWN?
Re-check your wiring.The AUTO-MAN switch for the fan only switches the fan on, leave it in auto.
Feb 11, 2013 | Heating & Cooling
Can not start heater, does not prime,think it might the pump.
You have a classic Reddy Heater problem. I have a tip which will solve it at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters it details the problem, the solution and where to get the parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 06, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I had my heater on and when I went to turn it off it showed "HH" in the digital display
On many types of heat controler HH stands for high,high set limit, if your unit shut down because of this-look@ the rear of the unit below the handle close to the fan for a reset, push it in and see if it starts back up for ya, hope this helps.
Oct 09, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
Reddy Heater 70 (Kerosene) won't start
In the same temperature range that is giving you trouble, run an ext cord (110v) from a known good household circuit and plug the heater into the cord. If the heater runs OK, then the inverter is your problem.
Jan 05, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater not turning on
the thermastat needs replaced!
Dec 09, 2008 | Reddy R70ET Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
80 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
