Question about Kenmore 5 cu. ft. / 142 liter Upright Freezer 24501
Leaking oil from crimped copper line
If I can fix the crimped line, how do I put oil back into the motor, and what type?? - James (Kenmore 6\ Embroco PW4,5 - 1 hp motor)
  • orcaveman Dec 20, 2008
    If I need oil, how do I insert oil??
  • 700 Answers
First off there's probably no refrigerant in the unit. the amount of oil is probably minuscule to what the system has.
Posted on Dec 20, 2008
  • 1 more comment
  • Todd Born
    Todd Born Dec 20, 2008
    when you pull a vaccum on the system you can pull it into the unit while its on a vaccum.
  • Todd Born
    or use a oi pump that you hook up to the suction and then you add oils with the unit running
  • Todd Born
    Todd Born Dec 21, 2008
    by either pouring a little oil into the hose and then adding refrigerant or when the unit is on a vacuum take the hose and **** some oil into the unit while the pump is running. you have to have the pump on the high side and just a hose on the low side.
Why is my freezer not freezing
I had this happen to my freezer and I had to install a fan in the freezer by a repair man and then it worked like brand new.
Jul 18, 2012 | Bush BAF55143W Freezer
Would like to know if laying a feezer onit side would harm the freezer in any way Paul
As long as the freezer is not plugged in while on it's side and after you put it right side up you wait an hour to let all the compressor oil drain back to normal nothing bad can happen.
Sep 14, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Side of freezer seems warm
Hi!!
Don't worry about the line, it is supposed to be the way it is. If you are talking about the condenser coil, located on the back bottom part of the unit, with a small fan in front of it, yes, it is supposed to be hot.
The condenser job is to disipate the heat absorbed by the evaporator (the coil inside the freezer). Make sure the condenser is clean and condenser fan is working, also, make sure there is air circulating thru the back of the unit to help cooling the condenser.
The noises you hear, are probably the defrost coil melting the ice on the evaporator, this function is on a timer and happens 3 or 4 times a day.
Good Luck!!
Aug 03, 2010 | Woods 247 cu. ft. Upright Freezer FU25
I noticed a crimp in one of the copper tubes
see if the repairman can come out and replace,it may not cool properly
Jul 05, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Kenmore leaking oil
Hi!!
You have a Refrigerant Gas (Freon) leak. Oil travels with the Refrigerant Gas thru the system, that's why you see the oil on the drip pans, if you look closely you should be able to know where is coming from.
For what you are telling me, it seems that the leak is of considerable size, I recommend to ASAP take freezer to a Kenmore authorized service station for a repair estimate, then you can decide to fix it or get a new one. If you call a repair tech, he will charge for the house call regardles.
Good Luck
Don't forget to rate this post.
Jun 04, 2010 | Woods Upright Freezer V1613RW3
Small freon leak, food safety
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Sep 23, 2009 | GE Freezers
Marine refrigerator needs recharge w 134. how can I install a schraeder valve in crimped suction line? If I desolder line and install valve will crimp uncrimp with sideways squeeze? Or do I have to cut...
This is not a DIY job, You have to call in a refrigeration service man to do this job. Although you may know a little bit about refrigeration soldering and a bit more. Do you have a vaccumn pump to vaccumn the system to 500micro or lower before you recharge the freon. If you do then I don't think you would ask for any question at all.
Jul 06, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
How to hook up water line from sink to icemaker.
You have to put a T between the cold water valve and the faucet, then run a plastic or copper line to the refrigerator(the size could vary from 1/4' to 3/8", you have to look at the water valve in the bottom back of the refrigerator).
Apr 24, 2009 | Freezers
Fluctuating temperature..
could be a freon leak check condensor lines were you see the oil if lines have oil on them then it is leaking slowly and you need system work
Aug 26, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Kenmore 5 cu. ft. / 142 liter Upright Freezer 24501 Logo
194 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
