Question about Gateway M305CRV Notebook
Monitor not working
When I turn my computer on I see the Gateway welcome screen, then the windows loading screen, then the screen goes blank and you can hear windows start but can't see anything. Could the motherboard be shot like my friend says it is?
  • 2 more comments
  • Anonymous Mar 11, 2008
    My gasteway M305crv screen is very dim. Pre\vious to this I got new Microsoft Office installed. At restart- screen is very dim? What happened?
  • Anonymous Mar 13, 2008
    my monitor screen continues to flicker. Sometimes it goes black and I have to wait to resume my task. What can be going on?
  • Naniblu Jun 09, 2008
    I am using a ac adaptor my battery needs to be replaced. Is this the reason my screen is not working while I have the ac adaptor plugged in. I can barely see the monitor screen unless i pull out the adaptor for a few seconds - only..... Then I can see the screen light up and but I have to put the ac adaptor right back in or the computer turns off,. Thank you
  • Anonymous Sep 02, 2008
    I have the same problem on my HP laptop. The HP boot screen appears, then you see the microsoft bar, then the display goes black. You can hear the windows starting music but with the screen black I can't tell what's going on. I seem to be able to type in my windows password and the boot will continue. Safe mode works okay. This may somehow be related to the battery and AC power. I always run off of AC power. The battery no longer holds a charge as a result.
    Re-installing windows is such a drastic measure. Any other thoughts on how I might fix this problem?
    Novelist:
  • 198 Answers
Hello Chrispa22, Rest assured, it isn't a fried motherboard. If it had been you woun't see anything on the screen. It's as simple as this. Your problem is related with the windows instalation you currently have. Try to boot the windows in safemode to see if the problem still manifests. If you have 2 partitions on the hard disk move all important data to the one not containing the windows files. The cleanest way to fix this would be to reinstall windows. Format the C: partition to make yourself a clean install. After the install everything should be fine. If you need more assistance please reply back or contact me on the live assistance.
Posted on Apr 03, 2007
I've seen this issue in the past and it might be a simple fix what sometimes happens is the monitor defaults to a different display ie:you have also used the tv as a monitor etc. try hitting f8 on start up go into safe mode and reset the display its supposed to use hope this helps
Posted on Feb 03, 2009
Repair instead of reinstalling,u lose every thing if u install OS after formatting
Posted on Jan 24, 2008
SOURCE:
My monitor goes blank after a while,power light still on,why is this & what can I do?
Check connection cable with videocard on your PC, unplug it and carefully plug it in again. (Turn off your monitor during this operation). If monitor goes black after loading OS (like Windows), then your screen resolution higher then monitor can support. Load computer in Safe Mode and lower screen resolution.
Aug 10, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Screen truns blank after starting up
Check the caps all eight and the 5v transistor it's seem like it braking down under a load (heat up and shut down)
Mar 11, 2009 | Gateway FPD1975W 19" LCD Monitor
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Blank monitor
Try this.
Turn the computer off.
Press F8 on the keyboard and select safe mode.
See if the monitor is corrected with that process and restart windows in the normal mode.
Jun 11, 2008 | Gateway 310S (2900621) PC Desktop
Monitor displays breifly then goes to blank screen
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Gateway M305CRV Notebook Logo
1,419 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
