Question about Panasonic PT-53WXD63 53 in. Rear Projection HDTV Television
Newer 53" panasonic rear projection w/ RED WAY OUT OF convergenc
5 year old 53" panasonic rear projection (PT-53WXD63G). Red is so far out of convergence (way to the left on the screen) that I can't use the remote control adjustment to bring back into alignment. I took the back cover of the tv off and all 3 bulbs are still working fine. Is there a way to adjust the red bulb or do I have another problem.
  • Anonymous Jan 01, 2009
    yes but mine is Green way out. And the green seems to jump around.
    Sergeant:
  • 233 Answers
The color has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps!
Posted on Dec 21, 2008
Panasonic PT-53TW54 - No red colour
the lamp is busted you must check weather the lamp does,t work at all.
Jan 12, 2012 | Panasonic PT-53TW54 53" Rear Projection...
I have a Panasonic 53" PT-53x54- 53" turns on for 5 seconds then
It is very common for the high voltage tranformer or flyback to wear out and not provide adequate power to the tv. You can test them with an ohmmeter to see how much powrer is being sent to the main circuit board. You can get parts at tigerdirect.com
Dec 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
PT-53WXD63G with same problem...
one of the stk ic's is bad and probably the the resistors controlling it. It is my custom to replace instead of only one
Sep 06, 2009 | Toshiba 53H71 53 in. Rear Projection...
Panasonic PT-53WXD63G convergence problem
Hey, you are in my area--I live in Santee--let me know if you want me to do it. shoot me a email if you want my instructions so you can do it yourself.
etower.766@netzero.net
Aug 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Pt-53WXD63g led blinks 3 times
that is an indication that you need to replace the convergence IC's if you are handy and can do light soldering please contact me at techman32katyahoodotcom for a DIY solution and save yourself at least 400 bucks or so
Aug 06, 2009 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
53"panasonic television
UPON POWERING UP, MONITOR STAYS ON FOR APPROXIMATELY 5-7 SECONDS, THEN POWERS OFF. RED LED FLASHES 3 TIMES..PAUSES...THEN FLASHES AGAIN 3 SECS.
Jan 31, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Red bulb
convergence amp ic are bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 19, 2008 | Panasonic PT-56WX53 53" Rear Projection...
53" Panasonic HDTV showing letters and shadow
maybe you have defective convergence correction circuit! replace a new one!
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WXD63 53 in. Rear Projection HDTV Television Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
